Sewell 2011 Headlamp Kit & AFS
Did anybody buy and install the Sewell 2011 headlamp kit on a car equipped with AFS? One poster here said he did and his AFS light continuously flashed. I spoke with Sewell and they said nobody they know with the kit has experienced a flashing AFS light, just a steady lit AFS light.
I'm trying to see if anybody else has an experience with the Sewell kit they can share in terms of what their AFS light is doing (lit or flashing).
how did you remove the bulbs? i heard it was a part of the circuit board? if so, what tools did you use to remove it?
1.Did you have your car lowered or do anything else that affects AFS?
2. Did you turn the AFS off via the switch on the lower left part of the dash before the install or was AFS on?
3. Do your high beams still have a low light visible? I'm trying to figure out if my DRLs need to be turned off either before or after the 2011s are installed or if the DRLs can stay activated.
My car has been lowered for awhile, springs than coils. Both installed professionally, none of the AFS sensors were messed with. Never had a problem
AFS was off before install, but still didnt make a difference. You cant lie to the BEAN system is my guess.
DRLS can stay active but you will have both the led strip and the older DRL on at the same time. My DRLS are disabled.
Ill post a video shortly. Ill upload it to my youtube acc
AFS LIGHT FLASHING
http://www.youtube.com/watch?v=JBJG5E2zcW0
AFS LIGHT REMOVED
http://www.youtube.com/watch?v=XfzX4FMXcZw
AFS LIGHT REMOVED
Cruiseman
05-19-13 09:45 PM
CCJ22
12-12-11 08:17 PM
