06 IS350 battery put in backwards and boosted and now it wont start. Suggestions??
Yes its the fusible link or sometjing i soldered mine cheaper then buying the whole link i saved like 300 dlls they usually break or crack when they burn up or pop since they are made with aluminum plate that happens when they blow up that causes when put battery csbles backwards good luck man
Sounds like more than blown fuse. Something fried. I never heard unmarked battery post. Don't even have a multimeter if that is the case. Hindsight. Sure battery is good, putting out correct voltage?
Super Moderator
Look at the posting dates. Original poster had problem seven years ago, second poster with this problem posted in the thread in August 2016. I think it's safe to assume that both have fixed their issues by now.
looknow12
06-07-05 06:52 PM
