You need at least 10 mm spacers but I would go with 15 mm with rolled fenders. Try b2designs he's one of the vendors here with pretty competitive prices. He's a good guy.
if i run 10mm + ET38 = ET28 i would need to roll fenders right?
I think you should be fine. I'm running 9.5" +25mm offset, slammed... and I JUST had to roll my fenders a little. But you can always measure the distance from your wheel to the fender (parallel to the road, of course) and see how much you can space them out. But at this height, I wouldn't even worry too much.
thanks man i've been driving for a couple days with the 19s on and only rub when i make a sharp turn. i check the tires and see no visible rubbing marks so i'm guessing it's hitting the liners?
Most likely. I have holes in my fender liners from rubbing. haha
