Dashboard Sinking
Old 05-11-11, 03:35 PM
rizzy
rizzy's Avatar
Default Dashboard Sinking
I just noticed today that the area where the dashboard meets the windshield has sunken down. It's only sinking in front of the gauge cluster "bubble". Has anyone ele had this issue and remedied it?
I'm going to remove the cluster and see if I can push it back up. Is there a DIY for removing the cluster?
Old 05-11-11, 03:37 PM
shadowman
shadowman's Avatar
Do you mind taking a picture so we see what's wrong and offer the advice?
My guess is that it probably got warped from the sun light and heat. If that's the case, I don't think it can be pushed back.
Perhaps something can be inserted underneath to push it back a little.
Old 05-11-11, 05:08 PM
jbjones85
jbjones85's Avatar
pictures would help as I am having a hard time picturing what your talking about.
Old 05-11-11, 05:42 PM
rizzy
rizzy's Avatar
Old 05-11-11, 08:31 PM
brociouz
brociouz's Avatar
Is your car exposed to a lot of sunlight?
Old 05-12-11, 05:06 AM
rizzy
rizzy's Avatar
Yeah for about 4 hours while I'm at work.
Old 05-12-11, 05:27 AM
s6 4rings
s6 4rings's Avatar
Mine has a little bit of that, but I don't remember it being any different from new
Old 05-12-11, 07:55 AM
rog1206
rog1206's Avatar
Same here but it's on both sides and it looks even. If you look closely, you should see some vents for the defroster. Try sitting in your passenger seat to see the sag on the passenger side.
Old 05-12-11, 10:12 AM
rizzy
rizzy's Avatar
Checked it out and the passenger side is right where is should be, and the drivers side is sunken in.
Old 05-12-11, 11:21 AM
iRock
iRock's Avatar
You must have a350 with that MPG you ever sit anything there while it was super hot? I put my sunshade up religiously to try to delay things like this. Doesnt look bad though
Old 05-12-11, 11:22 AM
brociouz
brociouz's Avatar
If you're still under the original warranty, this should be covered.
Old 05-12-11, 11:31 AM
rizzy
rizzy's Avatar
I was waiting for someone to comment on my mpg . But no, I do not sit anything there, ever.
I am about 11k out of the original warranty, and I'm assuming it's not covered under CPO warranty.
Old 05-12-11, 11:34 AM
iRock
iRock's Avatar
Yea I get ****ty MPG to.... 18.5 last tank its worth a try to check and see if its covered under CPO
Old 05-12-11, 11:35 AM
brociouz
brociouz's Avatar
^ Probably not, but it's worth asking. I recommend going to several different dealerships and asking, in person, about it (ideally when you need some other kind of service done). Don't let them write you up for the complaint either or they'll see you've tried asking multiple dealerships.
Old 05-12-11, 11:45 AM
rizzy
rizzy's Avatar
I need to do the fuel pressure sensor recall so maybe I'll ask them when I go in for that.
Quick Reply: Dashboard Sinking
