taking car in to do TSB carbon + recalls
so i'm taking my car in to do some recalls and TSB carbon build up..
i have a f sport intake.. would it be a good idea to put the stock back in ? .. and also i haven't been servicing the dealership last oil change .. will they try to relate the rough idles to that ?
Sorry to hijack your thread, but i have a question about the TSB. Do all lexus IS x50 get to do them? Because I have a 2006 is250 and wondering if I can get the TSB done for the carbon build up? Thanks ahead!
Since you have the F Sport Intake I don't think you will have to remove it. With it being a Lexus Product that they sell, you should be good to go.
If there is a TSB or Recall, all they will have to do is duplicate the problem. So they can see it with their "own eyes." If it's a good dealership, I don't see you having any problems.
This is from Lexus....
https://www.clublexus.com/forums/att...0029-10-1-.pdf
@sffd103
I was wondering what are some of the symptoms to tell them when I go in for the service? Just want to be prepared, thanks!
Also, my car is approaching 60k and will need to do the service package soon. Would it be cheaper for them to change the spark plugs and do the brake fluid change at the same time? Since they are already doing some sort of work on it?
No reason to remove the intake.
TSIBs are free as long as the car is under warranty, after that they aren't.
Recalls are always free.
and there's not really much/any overlap I can think of in the labor of changing brake fluid and changing spark plugs, though both are due at 60k miles. Just be sure to ask for the pricing on JUST the items you need done, not "the 60k service" because otherwise the price will go up considerably and you won't get anything extra for it.
I want to come in to get this TSIB taken care of when I take my 08 IS 250 AWD to the dealership for the 64,000 km service.
As with others, it may be difficult to duplicate, but my IS does vibrate noticeably when idle in drive.
Can those who have had it done share some tips? I have CPO warranty, so it's covered right?
There are some other threads about this that have more info. It sounds like the latest TSB involves taking apart portions of the engine and rebuilding the offending parts. Quite a job.
I just made an appointment to have mine looked at for the second time and will report back what they say. I already told the SA he's not going to experience it, since it only happens once every few weeks. So we'll see.
Check this thread: https://www.clublexus.com/forums/is-...d-threads.html
my is250 has just hit 70k , i took it for service 2 months ago, and i told them about the carbon build up, and how the car seem like its gonna turn off when completely stop, and they service guy said it would cost 690 dollars to get fix.... i still have not done the service. im thinking of calling the dealer and see if i can work anything
Also, if you buy the spark plugs, most dealerships will replace them for free or at a minimal cost while they are in there performing the top engine clean. Top engine clean doesn't have anything to do with the brake fluid flush though, so that they will charge you whatever they usually charge. The top engine clean requires an oil change, twice actually, so if you use a specific oil, or need an oil change, keep this in mind. Might want to have them refill with whatever you usually put in on the second oil change.
As others have already said, this TSIB is covered by any Powertrain warranty
I wonder tho, is this covered up to 100k if you have the CPO warranty? I'm sure someone knows
