View Poll Results: Should I change wheel Size at all?
Multiple Choice Poll. Voters: 14. You may not vote on this poll
2006 IS 250 Wheel Upgrade??
I've been considering changing my 18'' wheels to 19'' or perhaps 20''. What are the pros and what are the cons or should I even change the size at all? what do u think?
my standard 16" wheels on 2008 is250 looks really bad on the car.
so changing wheels is compulsory for me.
upgrading to 19" full face fsport.
*its going to look much better but damper will be more harsh
U had 16'' from the factory on a 08 IS250 model? thought they all came with 18'' wheels
My IS250 had what they call a "staggered fit" on the wheels which means the rear wheels are thicker than the front on the factory 18'' wheels. I got after market rims on it 18'' but all the tires had to be the same thickness (the thickness of the thinner factory 18'' front wheels) now there is too much space, for my taste, on the current rear 18'' wheels that have become thinner with the new rims that I got. If I go with 19'' rims should I try to get them "staggered fit" or just let all the wheels and tires be the same size?
cant really see the wheels can u send a larger image or an image I can zoom into
18 is perfect for IS. you have to consider the versatility or usability of the size of the rim. everyone is gonna tell u bigger is better, but this could be costly. you mite have to change tires more often. rubbing issue mite occur.
I have 20's on my car and I love the look. It's what I was going for. Big wheels and slammed. You have to ask yourself what will be the use for your car and how much/far you drive. Will you lower? Staggered means the rear wheel is wider, as in 19x8.5, 19x9, or 19x10. you can read up on different sizing for your car. Good luck on your choice. Here is a pic for reference. Not a daily driver, but I'm static. Just dropped on coilovers.
I just got new wheels today for my 06 is250. I went from 16 to 19 and it looks great.
When anyone changed their wheel size, did you have a little discrepancy with your speedometer? It seems that my speedom feels a little slower. which is not good where I'm from as emission tests require accuracy...
