Help!! Check VSC Light came on
So i changed my halogens to HIDS from HIDEXTRA.com and after i changed everything and tested everything, i tried to start my car up and the "CHECK VSC" and engine check Light came on, Should i be concerened?
Yes, in that you don't know what's going on yet. There's likely not a problem with VSC - the VSC light comes on because VSC is automatically disabled every time a Check Engine light comes on.
The only way we can help is if you read the code. Either get an OBDII scanner (very useful to have, and inexpensive) or go to Autozone or your local shop and have them check the code, then post them here. That way people can see whether they've had the same codes or not.
First thing though is go out and tighten your gas cap.
Same thing happened to me. On two different occasions. I restarted the car, or reset my system and it disappeared. Haven't seen it in months, and have gotten my maintenance and such without problems. I wouldn't worry about it unless it shows up frequently.
