Tire treadwear question..
Old 05-20-11, 04:51 PM
mong
mong's Avatar
Default Tire treadwear question..
I have the Oem's Bridgestone RE33. Right now is at 19k mileage but it still got a decent amount of tread left. I notice my front driver's side tire is wearing out more then the rest. The part of the tire that is wearing out is the inner edge of the tire. Is my toe off or is it due to something else? Any input would be awesome. Thanks.
Edited: dropped on f-sport springs.(did a alignment @ firestone 2 weeks later after installed)
Old 05-20-11, 05:04 PM
Byprodrive
Byprodrive's Avatar
That issue is standard on the 2nd gen IS. My research indicates it is caused by a excessive toe-out spec from Toyota. Consult a expert non dealer alignment shop for solutions. My 2007 IS was showing steel belt @ 19,000 miles.
Old 05-20-11, 05:24 PM
mong
mong's Avatar
But is just the driver's side that is wearing out unevenly..
Old 05-20-11, 08:32 PM
rich250x
rich250x's Avatar
yea its most likely your toe on just that side
Old 05-20-11, 09:11 PM
mong
mong's Avatar
Yeah, I'm going to take it back to firestone. Good thing they have the 12-month/12,000-mile limited warranty on it! So it SHOULD be free.
Old 05-20-11, 09:25 PM
Hoovey689
Hoovey689's Avatar
wow 19K is a lot better than the 9K I got with my ER33 when dropped on F-Sport lol
Old 05-20-11, 09:47 PM
mong
mong's Avatar
^^^ Dude.. there still like 5-10k worth of tread left on my tires! is just my front driver's side seem to be balding out.
Old 05-20-11, 09:55 PM
Hoovey689
Hoovey689's Avatar
Good thing you have the warranty. Yeah the Toe and negative camber on the IS is a b**** hah
Old 05-20-11, 10:02 PM
Sango
Sango's Avatar
Factory alignment is bad. Go to a dedicated place to do it, that should fix it.
I had to get new tires because tires when I bought my vehicle CPO back in late August, the tires were compromised due to bad alignment (the dealerhip supposedly changed 2 new tires and did alignment). I went to a dedicated shop get alignment done and a set of brand new Michelin Pilot Sport A/S and driven them for just over 12K so far and recently rotated them. Tire wear doing well as expected and I get them checked about every 4-5K or so at the alignment shop as per their recommendation.
Old 05-20-11, 10:07 PM
mong
mong's Avatar
I'm just gonna run 0 degrees toe front/back and run factory spec on the rest. I should be OK.
Old 05-21-11, 02:10 AM
Sango
Sango's Avatar
Make sure all the numbers make sense, than just running factory spec. Factory spec could be still off if not done properly and simply match up the green lights!
There is my alignment report, you can see how bad is was off. The alignment person had also did some adjustments to correct the geometry of the car. According to one of the modetators, the report seems to indicate that the subframe was adjusted.
Old 05-21-11, 02:28 AM
TofuMaster
TofuMaster's Avatar
...thats not even that bad. my rear toe was off by a few mm and both tires are showing steel belts after 4k...and i got my alignment checked every 3 months
Old 05-21-11, 03:38 AM
ApokC
ApokC's Avatar
Mong has crooked toes! Haha
Old 05-21-11, 11:35 AM
Sango
Sango's Avatar
I would say it was bad because I ended up replacing all 4 tires within less than a month after purchasing the vehicle. Besides, that they put the 2 new tires in like odd locations, like, front right and rear left. The alignment person who felt the old tires after replacing them did say, they were pretty much ruined.
Old 05-21-11, 11:39 AM
mong
mong's Avatar
That's a negative sir! My toes are "within spec" My front camber was a bit too negative. Can't do anything about it cause you can't adjust the front camber. Oh well..
Quick Reply: Tire treadwear question..
