Best Way to Install 09 Front GFX Lip Without Drilling?
I use 3m tape but I can never get it to be perfect, the tape either stops sticking eventually or some parts will not make good contact with the bumper therefore leaves some gaps.
Anyone have a good method for making it stay on perfectly?
I'm about to install that lip too. I actually pm'd a few members to get some tips. One guy said he's having problems with it sticking using 3m tape only. This is only my temporary lip, so i'll try cleaning real good and use a adhesive promoter and see if it'll hold for a little while.
The 3M tape sucks for installing this lip. I've tried using the 3M automotive tape with adhesive promoter, heat gun, and cleaning the areas with rubbing alcohol before installation. It holds up for a little while but then comes loose. It separates from the bumper along the front where it takes the most force from the constant wind load. I screwed some self tapping screws along the underside of the lip so it wont fly off.
I even tried using epoxy and that didn't work. Nothing seems to be able to bond with the plastic on the back side of the lip. I even sanded it down to make a rougher surface for the adhesive to bond to.
I'm just going to take it to a body shop and have them attach it.
If you look at the inner bottom of the lip, it should be pretty obvious where to locate the clips. Part of the clip goes in the slot on the gfx, the other part goes on the bumper so that the gfx and bumper are sandwiched between the clip. There are 3 clips on each side. Make sure you press the clips in all the way, so that you hear a "click".
