IS250 swap to ISF question
i have a crashed isf and im debating if i could get a chassis for real cheap off a 250 then it might be more worth it. i just need to be sure that everything will fit.
Lexus Connoisseur
Didn't you already post this in the IS F forum a minute after you posted this?
https://www.clublexus.com/forums/is-...-question.html
here is a thread about someone trying to build an IS-F in a IS250
https://www.clublexus.com/forums/is-...to-is-f-3.html
In one of his post he says that the IS-F is longer than a normal IS to accomodate the 5.0 L engine. So the answer to your question is no, your IS-F engine will not fit inside the is250.
Thanks for all the response guys, really helped me out.
I'll probably be staying away from it then, better not go through the hassle and in the end just keep building up problems and receipts!
