Any good cheap wheels?
1000-1300 WITH tires is not gonna happen if you want something that is gonna be aftermarket and even a bit decent. Even if you buy cheap tires and they cost you about $500, your looking at $500-$800 for a set of 4....and quality wheels are not gonna be in that range. I suggest you save a bit more, buy some Linea Corse wheels or something...they are about $1300 w/o tires if you want a decent wheel that wont break the bank
I know your worried about bending nice wheels but here's the thing:
If you buy cheap wheels, they will only bed faster/worse. You'll spend more money probably buying cheap replacement wheels cuz they bend all the time, then if you had just bought some quality wheels that are much less likely to bend.
Save some cash, buy some good wheels, some good tires, and be you'll be happy you waited!
I'd say the things you want aren't entirely possible. While you can get cheap wheels, they may not be the best quality. That being said, I don't think they're gonna fall apart just cause you drive a long distance/bad roads. While I was a college student I had ok wheels and now that I'm an old may I have $5K wheels. So, get what you like and don't worry so much that you can't afford 3K wheels. You'll have plenty of cars in your future.
I believe there has to be some bang for your buck wheels! And more like going out to the city, that makes my wallet thinner
too expensive
Yea ive been looking into them, are they strong enough though?
I like the CF5 more, but still too expensive lol over my budget without tires
too expensive
M3forum.net:
-1 of the wheels have a small crack on them that can be repaired (does not hold air)
-1 wheel has a small crack but still holds air (but can also be repaired)
-1 wheel had a crack and is repaired and works perfectly (no bends no cracks)
-1 wheel is in perfect condition (perfect as in no cracks no bends)
Zilvia.net
19" Staggered Linea Corse LeMans
SPECS...
Hyper Silver / Polished Lip
19x8.5 (15) 5x114.3
19x10 (20) 5x114.3 ( 1 wheel has a minor crack on the inner lip due to a blow out that i couldnt prevent and for that i will bring to get professionally fixed)
m5 board:
-One of the rear wheels is cracked in 2 places. One of these cracks causes the tire to slowly lose air pressure.
-One of the front wheels has some grime that seems to be underneath the clear coat. I was able to scrape some off with a fingernail but it also took off the finish on the wheel.
Even one on our own forum:
Only problem is a few curb rashes which are barely noticeable, and the right rear wheel has a hairline crack. I can get it repaired but dont feel like going through the hassle. if buyer wants to negotiate i could probably fix it for a good price before you buy it.
https://www.clublexus.com/forums/whe...r-vouched.html
There is probably 50 more on the list. But you get the point...
Thanks guys, i had a feeling everyone was gonna act like this... I just thought that maybe there would be some good deals out there /:
whether i get them or not im gonna go look at my local wheel dealer, which has high end and low end wheels.
just curious has anyone have an opinion on rotas? these look decent http://www.wheeldude.com/catalog/pro...oducts_id=1015
opinions?
opinions?
opinions?
opinions?
http://www.google.com/search?um=1&hl...i=g10&aql=&oq=
Honestly I would save up a little bit more to a budget of at least 2k or 2.5k for wheels plus tires. You can find more decent rims at that price range. Yah it might take longer to get your wheels but I don't think you'll regret it. Some good rim choices at that range are xxr's, tsw's, and Linea corse.
I think im gonna save up to buy Linea Course 818. Ive been looking through some threads and they look nice. Are they good quality? I heard they are the same manufacturers that make rota, which you guys said are not good.
Opinions?
Opinions?
