06 IS350 HID Headlight Problem!
Having an issue with my 06 IS350 passenger side headlight hid. I noticed the other night that it was out. Then yesterday I was driving to a location very close by and pulled up behind a truck, I noticed in the reflection it was also out so I turned it off and turn it back on and it came on again. Then when I left my location on the way home I saw a car flash its lights at me, when I arrived home it was out again. But turning them off and turning them back on fixed it.
I don't feel like its a ballast overheating issue because it was not on for a substantial amount of time.
I have heard some people say they just replaced the bulb and it fixed the problem (im hoping this isn't something worse).
Any ideas or similar experiences? I've done a bit of research but I'm still unsure. I also posted this question over at IS, just really looking for some answers.
My car is an 06 IS350 with 59,000 Miles.
Thanks
Thanks
It's hard to tell which one is causing the problem. You'll just need to do trial and error to pinpoint if its the ballast or bulb. I had the exact issue you described (would go out, but would turn right back on via the stalk) not too long ago and it turned out to be my bulb. If you notice the bulb is slightly more purplish than the other when on, that's a sign the bulb is going out.
I'd try flip flopping the driver and passenger side bulbs to see if the issue still happens on the same side or if it follows the bulb.
Try switching the passenger side and driver side bulbs and see which side the problem occurs on. If you switch the bulbs and the other side has the problem, then it's the bulb that needs to be replaced. If you are still having the problem on the same side, then it might be the ballast.
Most likely it is the bulb that is the problem. If it is, you should replace both bulbs at the same time.
I just bought the car a few days ago, loving it, but hated finding this out.
I managed to get the dealer to pay the toyota dealer near me to order and replace it, so I'll go in and get the new bulb put in tomorrow.
However the other bulb is great, should I just pay for the other side too? or wait for it?
Try these:
http://www.amazon.com/Toshiba-Xenon-...=pd_sbs_auto_1
I ordered a set from this same seller who also sells them on ebay. It's a really good deal because they're basically stock.
The dealer should be replacing both bulbs if that's the case. If they don't, I'd argue it, especially since you just bought the car. If they absolutely refuse or whatever, this would be a decent time to get an aftermarket bulb in case you don't like the OEM temperature much. I wouldn't pay the dealer for bulbs...they're going to charge you up the butt on that!
Try these:
Seems pretty typical that the OEM D4S bulbs have a short lifespan. Brother in law's GS with 32k miles had 1 bulb go out last year. Also my buddy's IS350 bulb has been doing that intermittent deal where you have to turn them on and off to light up on the driver side. These bulbs aren't purple either when they give like a typical D2S bulb does after 2000+ hours.
