Water Pump
Old 03-09-12, 08:33 AM
Mancebof
Mancebof's Avatar
Originally Posted by B16da9
Mine failed at 55k miles, however mine was not leaking but doing bearing noise.
Could that be the clicking noise i hear comming from the wheel well?
Old 03-09-12, 08:39 AM
B16da9
B16da9's Avatar
Doubt it as the bearing failure is more of a "Whooshing sound". If you only get the noice after the car has been siting a while and you move it it's probably the brake pads shifting around.
Old 03-09-12, 05:20 PM
Gville350
Gville350's Avatar
Lexus unfortunately sourced some very problematic water pumps. Anyone know what the manufacturer is of the OEM water pump that came on the car from the factory?
Old 03-09-12, 06:21 PM
RAMAIR
RAMAIR's Avatar
Two Weeks ago I heard a bubbling behind the dash, it was air in the heater core...
I drove to lexus and they changed the water pump the next day and gave me a loaner for free under the power train warranty. Mine is a 2007 with 49,xxx miles on it.
The total bill was $540 odd dollars. they did the pump, the upper and lower hose, and the fluid change.
e-man
01-12-14 10:36 AM
MyIS350G
02-10-12 07:50 PM
lukeisf
IS F (2008-2014)
08-07-11 07:52 PM
TuReckless
11-13-10 10:30 AM
Colpup ES3
11-09-07 04:26 PM
Quick Reply: Water Pump
