anybody on here have 10mm bolt on project kics?
06-15-11, 02:45 PM
just wanted to see if anyone are rocking these. wondering if the bolts hit the back of the rim.
thanks for the info!
06-15-11, 03:33 PM
anyone have experience with these?
06-15-11, 03:44 PM
its going to depend on the hub design of the back of your rim. some rims are built with spaces or indentations between each hole, and some arent. your just going to have to check your rims. you'll probably need at least 10mm of clearance for the stock studs to clear.
06-15-11, 03:55 PM
this is why i asked to see if people actually have these 10mm spacers. i have a set of advan RS's
06-16-11, 02:28 AM
i have gram lights and kics spacers and i'm fine those advans should have space behind the hub for the extended studs
06-16-11, 07:31 AM
^^^ question is... Are they 10mm sir?
06-16-11, 09:57 AM
I have 10mm project kics spacers, they work fine with my AME's.
06-16-11, 10:42 AM
cut the front OEM bolt about 2 mm ish should be fine
06-17-11, 06:47 AM
Quote:
Originally Posted by
llamaboiz
I see.. Hmm I wonder if this would work on my advans.
Also these are for the rears.
Rokas
08-07-18 09:25 AM
L0ngJ0hn
08-24-17 06:17 PM
jspecvtec
IS F (2008-2014)
02-09-16 10:22 PM
eYezs1ck
10-08-10 09:10 AM
97Soarer
Wheels, Tires & Brakes Forum
07-01-09 05:16 PM
