Need Second Opinion on tires
Hello CL
Recently, not paying attention i was in the process of making a right turn and made it tooooo sharp and my back right wheel hit the curb (the type of curb with the steel edges and heard a loud noise.
Results: A minor slightly ripped sidewall and a tiny piece of chipped rim
I took my car to a specialty tire shop (Larkin bros. in San Francisco) and the guy just kept talking about how a new tire was needed . The tire is completely done
The tire shop couldnt get their hands on one saying the tire was special order (dunlop sport 2050) and said even though the curb/rim was only ripped , the tire is defected now completely and can explode
So i just ended up ordering a tire from lexus (300 bucks or so) and then I went today to get it put on and my dads friend which is the service advisor checked out the tire and said it was nothing. He said if it was his car he wouldn't even replace it since no metal was showing in the rip.. parts dept. ended up returning my money
I need a second opinion from CL since the parts advisor just glued the rip back to the tire
Not an area to take chances with.... Hit a corner at speed and have that section blow, you'll wish you had heeded common sense and not pinched a penny.
Replace it before it kills you or the family in the lane next to you....
Tires are cheap compared to life and limb.
V
V
I have the same thing happened to my tire and the cut was slightly deeper but smaller. I just bought perfect glue (type 1) and glued the loose piece back to the tire sidewall. I think any rubber to rubber glue will work (eg: rubber cement, gorrila glue, epoxy, etc).
I figure if there is a problem, i will see that the glue will fail to work and the cut would re-appear first and then I would change the tire before something happens but it has been holding strong for more than 1 year and still holding.
Hope that helps.
Hope that helps.
phillies
04-19-08 09:52 AM
