Anyone know how to remove the back seats and stereo? Also the gauge cluster?
I'm very cheap and tried installing some DIY tints months back. It went okay but today I ordered another pre-cut kit to try and make it perfect but failed hard. The front windows and rear windshield are the toughest. So to make things easier, anyone know how I can remove the rear seats and the stereo/sub or whatever it is back there. I'm trying to get as much room as possible cause it's just cramped back there. Also, I'm changing out all my dash lights and want to change out my needles to red or blue. Anyone also know how to get the cluster out? Thanks!
Rear seats are pretty simple.
Pull up on the bottom portion of the seat. There's 2 clips that hold the seat bottom down. One on each of the dots I made. Just tug it straight up and it'll come apart.
There's 4 bolts on the seat backing. Two are located underneath the middle seat, the other two are located one in each corner. With the seat bottom out, it's pretty easy to distinguish which bolts to remove.
After removing those bolts, I'd try to get someone to help you. Push the seat straight up about 4-5 inches to get it off the hooks and then it should be free.
I don't know how to remove the dash, so hopefully someone else can chime in
Gauge Cluster. remove both screws at top, Then there's two hidden screws behind the ect button area and on opposite side where the dimmer dial its at, pull both sides. They pop out just enough to get to the other two screws. Good luck!!
