Driver side window control working oddly
2006 IS 350 - Drivers side control will not open or close the two rear windows, only opens and closes divers window manually with no auto function (light also flashes) and passenger window works as should. Rear windows control open/close manually with no auto function. Help....
Tom
Tom
Super Moderator
Did you disconnect the battery? If so, you need to perform the following procedure described in the FAQ sticky at the top of the forum (I encourage you and everyone else interested in the second generation to read our FAQ - lots of great info): https://www.clublexus.com/forums/is-...isconnect.html
Thanks. Got it working correctly by rolling down then up each window individually at respective control . Yes, I did remove the neg bat terminal to clean up some corrosion and had hooked up a bat charger to keep from losing memory sets but must have lost connection.
johnmaher
05-21-19 01:43 PM
