Replacing battery soon! Options? Recommendations?
Old 06-24-11, 05:25 PM
calvin2376
calvin2376's Avatar
Thankfully I've never had to replace a battery on any of my cars, so bear with me on this question if you deem it a stupid one, but I'm genuinely curious for my future knowledge. Why would I ever spend more than $75-100 on a car battery, unless I have some crazy sound system setup or something that draws more power than usually necessary? Batteries to me (and again, I've never done the requisite research because I haven't had to, but that's why I'm asking) are kind of a commodity.
So what would a very expensive battery offer you over a $100 battery?
Also, as far as installation, I was under the impression it was fairly plug-and-play; take the old one out, stick the new one in. Is there anything complicated? Why would I need someone to install it?
Old 06-24-11, 07:03 PM
Bichon
Super Moderator
Bichon's Avatar
If you like to sit in the parking lot watching movies or listening to the stereo with the engine off, a deep cycle battery like the Optima yellow top is a much better choice than a conventional battery. Regular car batteries are designed to produce a large amount of power to start the car, and then immediately get recharged by the alternator. They are permanently damaged and won't last long if they are repeated discharged. Deep cycle batteries, on the other hand, produce a bit less starting power, but CAN withstand being repeatedly discharged.
Old 06-24-11, 08:04 PM
chi123
chi123's Avatar
For most older cars, it is basically plug-and-play. For ours, there's that protector thing that people sometimes have issues removing and little spacing is another problem. Otherwise, nothing more than disconnecting the terminals, out with the old and in with the new, and reconnecting them. Lots of places offer free battery installations with purchase since it's pretty easy and less time consuming.
Old 06-24-11, 08:09 PM
chi123
chi123's Avatar
Hmm, no wonder my battery is dying on me. When I go with my mom to the grocery stores, I hate going in with her since she takes a long time and I get mad , so I wait in my car and listen to the radio with the engine off. Usually I do this for an hour! Then I installed so many LEDs that drain my battery without the engine running. Now my battery indicator or magic eye is being bipolar. I brought a new battery and was right about to install it and noticed the indicator says "Okay" now! WTF! Last night it said it needed charging, now I'll just wait until winter starts to replace it.
Old 06-24-11, 08:20 PM
Bichon
Super Moderator
Bichon's Avatar
I'll be interesting in hearing whether adding all of that distilled water revived your battery. From your description in the other thread, it sounds like it was almost down to the top of the plates.
Old 06-24-11, 08:27 PM
robertrios
robertrios's Avatar
wait what battery indicator?
Old 06-24-11, 08:30 PM
chi123
chi123's Avatar
I'm definitely wanting to know if that is the case too. But if it really needed distilled water, it wouldn't show Charging Necessary but Add Distilled Water instead I'm assuming. I'm still confused since last night pouring the water in, the indicator didn't change but after driving around and buying a new battery, the thing changes to Okay, I thought I was crazy or something.
Do you think a volt meter can tell? I tested the battery when it said it needed a charge, and read 12.4 volts. I think I want to retest now to see what voltage it gets.
Old 06-24-11, 08:33 PM
robertrios
robertrios's Avatar
also what is the biggest yellow top you guys are able to put in your IS, im thinking about picking one up this weekend.
Old 06-25-11, 06:53 AM
Bichon
Super Moderator
Bichon's Avatar
You are confusing cause with effect. You removed the caps and had to add nearly a quart of distilled water to get the electrolyte to the proper level. That was your problem. The low voltage and partial charge was a consequence of insufficient electrolyte.
The magic eye is a chemical hygrometer that measures the specific gravity in just one of the six cells in your battery. It can be a quick way to spot a problem in your battery when you are under the hood, but it isn't a complex diagnostic system, nor is it sufficient to relieve you from the maintenance task of periodically opening all six caps and checking the water level.
A volt meter will only show you the state of charge, not the condition of the battery. 12.4 volts is about 75% charged. Fully charged should be closer to 12.7.
The proper procedure for testing a battery is to adjust the level of electrolyte, fully charge the battery, and then perform a load test.
Old 06-25-11, 11:03 AM
SuzIS250
SuzIS250's Avatar
+1 for the Stinger
Old 06-25-11, 12:45 PM
Proper 350
Proper 350's Avatar
I got a optima red top.probably never gonna buy nothing but optima from now on.But if you dont wanna spend the money and you dont power amps then you can go with anything.
Old 06-25-11, 08:05 PM
chi123
chi123's Avatar
Well, I installed the new battery today regardless. I got a Duralast Gold with 750 CCA for $115 which comes with a 3/yr free replacement. I tested my old battery with a volt meter and got 12.5 before I returned it to Autozone for a core refund. Strangely, I had to add 2 cups of water to the new battery to make it full. Now, my engine crank is better than before.
When you mean adjusting electrolyte level, to change the amounts of water? Adding some and removing some? Any way to determine if the cells are still good and able to hold charges?
Old 06-26-11, 06:00 AM
Bichon
Super Moderator
Bichon's Avatar
No doubt worth it for the peace of mind.
It means adding distilled water to bring the electrolyte to the correct level. To check for bad cells, charge the battery to 12.4 volts or higher, and use a hygrometer to check the specific gravity of each cell. A reading below 1.225 means you found a bad one.
Old 07-19-11, 04:36 PM
robertrios
robertrios's Avatar
which model optima yellow are you guys going with? My autoparts can only pull up a model number for a red top when I gave them my info.
Old 07-19-11, 06:15 PM
06tpis350
06tpis350's Avatar
Please need part no. For optima yellow top? Thank you CL =]
Quick Reply: Replacing battery soon! Options? Recommendations?
