DIY Steering Wheels Replacement
Old 07-06-11, 11:17 AM
brociouz
brociouz's Avatar
^ Sit in the driver's seat and use your knees to pop the steering wheel off, while using your hands to make sure it doesn't smack you in the face once it comes comes loose. Slowly remove the steering wheel and then tape the steering column so that it doesn't spin and stays in its original position.
It's not as scary/hard as it sounds.
Old 07-06-11, 02:35 PM
Kybball#1
Kybball#1's Avatar
I was watching the video and it looked like he loosened the 19mm bolt wiggled it off a bit , then took the bolt the rest of the way off and pulled off the steering wheel, it didnt look as if he taped anything. Will it be straight forward as to what i will need to tape?
Old 07-06-11, 02:50 PM
brociouz
brociouz's Avatar
^ The inner part of steering column spins. Don't let it spin. The tape is just a precaution so that it doesn't spin.
Old 07-06-11, 06:56 PM
Kybball#1
Kybball#1's Avatar
Thanks for all the help Bro, it was super easy.
Old 07-22-11, 09:16 AM
CCJ22
CCJ22's Avatar
Thanks for info on the spin issue.
Old 01-08-12, 05:23 PM
CCJ22
CCJ22's Avatar
Anyone have pics of what exactly is not suppose to spin? Sewell makes it look way too easy in their video.
Old 01-08-12, 05:44 PM
Joeb427
Joeb427's Avatar
I just bought the flat bottom all leather black stitching and IS-F steering damper.
The install is over my head.
If done professionally,how long would it take?1 hour,90 minutes...
Old 01-08-12, 06:31 PM
CCJ22
CCJ22's Avatar
Joe you can do it yourself. It will literally take 45 minutes. I've done it 3 times now on others cars but this is the first time I've heard of the spindle not allowed to spin. I never payed attention in the past and thus I bumped this thread for more input.
Old 01-08-12, 10:03 PM
brociouz
brociouz's Avatar
Make sure when you do the install your wheels are pointed straight, then when you take the steering wheel off the steering column just make sure nothing spins. It's kind of hard to describe in words but the top of the steering column has a part that rotates, you have to keep it in the neutral position. Use some tape to hold it in place if you're worried.
It's someone intimidating since you have to disconnect the battery and all, but it really is an easy DIY. 1 hour for the first time, 20 minutes after that.
Old 01-08-12, 11:47 PM
istarzan
istarzan's Avatar
Dudes, the steering wheel literally takes like 5 mins to take off. I installed my carbon fiber flat bottom steering wheel and total time with controls transplanted from OEM to new steering wheel was like 30-45 mins.
This plastic part with the wires connected to it, spins freely. The bolt lug you see in the middle doesn't move at all, with the car off and battery disconnected of course. Its nearly impossible to misalign the new steering wheel when you install it as the bolt lug has groves, so you can't put it on wrong.
Just loosen that nut you see in the first pic. Then you have to wiggle and pull and wiggle and pull, kinda like in the Sewell video. Its hard to get off but it will eventually. GL
Old 02-15-12, 06:04 PM
CCJ22
CCJ22's Avatar
^So the second picture that plastic piece is what everyone says should not spin?
Old 02-15-12, 06:13 PM
istarzan
istarzan's Avatar
No, it does spin freely. But you have to keep it in the same position in order for the new steering wheel to line up with the wires.
Old 02-15-12, 07:55 PM
CCJ22
CCJ22's Avatar
Ok wanted to make sure. I've done 3 steering wheels so far and wanted to make sure i did them correctly. Thanks
Old 02-15-12, 08:43 PM
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
If the spiral cable (some refer to it as the clockspring) is not in the same position when you put the steering wheel back on (for example you turn it 360-degrees one way), it will break. It can only turn so far in each direction from centre. It needs to be centered when the steering rack is centered. Leaving it in exactly the same spot is your best bet for this. Don't try to turn it.
Jeff
Old 02-16-12, 07:18 AM
brociouz
brociouz's Avatar
^ And if you do break it, expect to shell out big $$$ for a replacement. AMHIK.
Quick Reply: DIY Steering Wheels Replacement
