TPMS round Two Need help
So any ways I got my rims back from being powder coated and they came out pretty good. Just mounted up the tires today and they look really good too just one problem. The TPMS sensors are not reading :/ . They where fine B4 I removed the tires. What its doing is that the little orange traction light in the bottom right corner of the cluster blinks for a bit then stays lit. Nothing in the little display pops up and no red triangle either, just the orange traction symbol. BTW all tires are at 39psi
![](http://i4.photobucket.com/albums/y140/manno_one/photo.jpg)
I have tried to follow the directions in the lexus instruction manuel. But I think im doing it wrong. When I get to the point to press and hold the On/Off button in the int. screen it just goes back to the normal display "It says the traction light is supposed to blink three times slowly" but it dosnt. Any help would be a great help. Thank you for your time. and pics of the rims after I figure out TPMS issue
Thank you for your time and much Mahalo's
Rufio808
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
Rufio808
one of your sensors may have been damaged...
Have your lexus dealer scan for codes. and your tps is set up for the main set of wheels right?
Im asking about the TPS set up that can be changed through the **** on the left of the steering column where you can select between 2 types of TPS sensors. (EG. summer wheels and Winter wheels with diff sensors )
So everything got fixed, but what happened was the tire shop that mounted my stuff cracked one of the TPMS sensors. So my friend at Lexus gave me a new one for $100 and reprogrammed it and now everything is golden
, Thanx everyone for your input!!
Much Mahalo's
Rufio808
Much Mahalo's
Rufio808
NikonGuy
12-07-14 10:03 AM
