Old 12-16-14, 12:05 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Lexus IS Brake Guides
Print Wikipost
how much to change brake fluids?
Old 06-24-11, 11:14 AM
hazmat
hazmat's Avatar
Default how much to change brake fluids?
My dealership said it would cost 160 for the job is that a good price?
Old 06-24-11, 11:20 AM
uttam24
uttam24's Avatar
I am not sure about the dealership price but if you want to DIY then this might help:
http://shahryar.net/2011/05/08/chang...y-2008-is-350/
Old 06-24-11, 12:05 PM
Kurtz
Kurtz's Avatar
Was about $120 at my dealership (and only done there rather than DIY as I had little else to use my "free" Lexus card money on and brake fluid is kinda nasty to work with).... so 160 seems kinda high for a job that's, max, an hour of labor for em and just a few dollars in fluid.
Old 06-24-11, 12:53 PM
laobo979
laobo979's Avatar
Save 150 and diy as the bottle is only $10.
Old 06-24-11, 03:17 PM
KillaIS250
KillaIS250's Avatar
Best way to get the cheapest price if your not doing it yourself is to buy the brake fluid from the dealer than have a local mechanic/Lexus independant shop do it for you. It's not different at the dealership then it is with another experienced mechanic.
Old 06-24-11, 07:44 PM
Gville350
Gville350's Avatar
I made a $.50 brake fluid catch can. The $.50 was for the clear tubing purchased from Lowes. I used a large zip-tie container and its lid. Drilled a hole in the lid, and in goes the tubing. The key is to have the end of the tubing long enough and sitting below the fluid level...so that air doesn't get sucked back into the line.
Easiest DIY on this is like the earlier link/thread, install the catch can on the pass-side rear caliper bleeder screw and grab a partner. Using medium pressure and smooth/complete pedal compressions, pump the brake...while your partner mans the brake reservoir to insure it doesn't drop below the "LOW" mark on the reservoir. Continue until clear/fresh fluid starts to flow into the catch container. The clear tubing is key for this obviously.
Old 10-13-12, 05:09 PM
prech
prech's Avatar
Thanks for sharing -- just changed the 2IS brake fluid as part of the 30k service. Pretty standard stuff -- didn't even need to remove the tires as Rhino Ramps provided plenty of clearance
I believe it was 3/8" tubing for each of the bleed valves.
Old 10-13-12, 05:15 PM
sgmbab
sgmbab's Avatar
Just changed it for $44 at the dealership.
Old 10-14-12, 09:14 AM
RaceTech4
RaceTech4's Avatar
Kind of a bad idea doing brake fluid changes with the wheels on. It only takes one drop on your wheels to start eating the pain away. Do your self a favor and take the time to remove the wheels to protect your rims.
Old 10-14-12, 09:28 AM
edgeucated
edgeucated's Avatar
its around $100 at an independent mechanic. I got mine done for $85 since I paid cash.
Old 10-14-12, 12:01 PM
richf
richf's Avatar
$160 is a bit overpriced, $100-120 is average.
Old 10-14-12, 01:56 PM
edwinjaeho
edwinjaeho's Avatar
way overpriced
Old 10-14-12, 02:08 PM
starknight
starknight's Avatar
i had mine done for $100
Old 10-14-12, 03:33 PM
meis250
meis250's Avatar
My experience was:
Lexus dealer - 139+tax
Toyota dealer - 99+tax
My mechanic - 65
So your quote is rather high
Old 10-14-12, 04:46 PM
Shervin350
Shervin350's Avatar
110 at westside
Quick Reply: how much to change brake fluids?
