Key not detected???
Old 06-29-11, 08:12 PM
superdudu
superdudu's Avatar
Default Key not detected???
This morning when I was heading out to school, I try unlocking the car with the key fob, but there was no response, so after a few min of switching back and forth between the back up key fob and pressing the unlock button, I still couldnt unlock the doors.
When I finally got in the car, I couldnt start it. it prompted me to touch the key fob with the ignition and then voila! it started after that. Since I couldnt start the car with either the master key or the replacement key, is low key fob battery the culprit here?
and also, how do you manually unlock the car??
thanks for all the help!
Old 06-29-11, 08:18 PM
Justin2JZ
Justin2JZ's Avatar
Did you try unlocking it from the door?
Old 06-29-11, 08:23 PM
superdudu
superdudu's Avatar
yep, i tried, but no response. I had to stick a mini broom through the trunk opening to unlock the door because I didnt know how to manually do it so dumb of me.
Old 06-29-11, 08:27 PM
lexusis305
lexusis305's Avatar
You can pop off the cover and open it, but if just changed car battery open and close door a few times to reset system then push lock and unlock on fob when the flash the light then hold brakes and make sure you get a green light on push botton .if its not reading your key my have got disprogramed
Old 06-29-11, 08:30 PM
Sffd103
Fire Slayer
Sffd103's Avatar
This just happened to me a few days ago. Change your battery in your remote. It's dead!
Old 06-29-11, 09:03 PM
Justin2JZ
Justin2JZ's Avatar
Its a cover on the right of the button on the handle that you pry it off from the bottom. You can use the mechanical key to unlock the door.
hlippy4
11-07-18 08:56 PM
gtowne
08-06-18 04:02 PM
silkx3
12-04-16 02:35 PM
Stu
10-13-13 08:56 PM
sojah
08-17-09 03:35 PM
Quick Reply: Key not detected???
