DIY: How To Swap Cluster Lights (Inlcuding Needles)
#76
Here is the link to buy the MPH and RPM needles. We can send them in any color you want.
http://www.taninautoelectronix.com/2...lt_needles.htm
Be aware that the temp and fuel color will never match the mph and rpm color. The shade will always be off, it's even this way from the factory (different shades of white) because they are illuminated with different methods.
__________________
TANIN AUTO ELECTRONIX
262-456-4147
contact@taninauto.com
262-456-4147
#77
#78
#79
You can either:
1) Buy needles from us already repaired and install them yourself
2) Ship your cluster to us for repair in Wisconsin
3) Buy a replacement cluster already repaired from us
4) Drive down to San Diego and schedule an appointment with us and we can do the repair while you wait
#80
You can set something up in the future by giving us a call, emailing taninautocontact@gmail.com, or chatting through our website.
__________________
262-456-4147
262-456-4147
#82
They are the same. The car will function fine without the entire cluster installed. It will function fine with components removed.
__________________
262-456-4147
262-456-4147
ckev70 (02-18-19)
#84
#87
I just got my LEDs replaced "good enough to see" at a small computer repair shop in Philadelphia, PA (Mega CompuTech) that was willing to take on the task. All this shop did was resolder replacement LEDs for me, and I took apart the instrument gauge cluster and pulled out the needles. I first attempted to solder the LEDs myself and gave up after many hours of research and a few hours of soldering failure. My IS250 is 13 years old and not worth much, and although TaninAuto's work looks excellent and their dash disassembly instruction was great, I decided to attempt to get the needle's LEDs fixed at a small shop for cheap before committing to buying replacement needles from TaninAuto. I'm sharing because the tech/owner Manuel was nice enough to give it a shot, and since he's in Philly on the East Coast, it might be beneficial for some of us. I wrote a good review on Google since I was pretty happy with the repair. Call a nearby computer shop that can do soldering, show them some pics to see if they're willing to try, then good luck! YMMV.
#88
Did you destroy that board in that photo below?
