GPS override
Old 07-03-11 | 02:54 PM
Seabee1986's Avatar
Seabee1986
Default GPS override
Hello all. My wife's Lexus is a 2010 IS 250, auto transmission, AWD. When the car is underway you cannot use the GPS; its extremely obnoxious. Is there a way to override that safety feature?
Thanks in advance.
Old 07-03-11 | 03:02 PM
don's Avatar
don
I haven't read the thread but this may help you
https://www.clublexus.com/forums/is-...witch-diy.html
Old 07-03-11 | 03:34 PM
DrockSMASH's Avatar
DrockSMASH
gotta clip 2 wires behind gps unit
Old 07-03-11 | 10:38 PM
Seabee1986's Avatar
Seabee1986
Okay...I've yet to pull it out, but I'm willing to bet there are a lot of wires behind the unit. Could you be more specific?
Isn't there a way to turn it off using the cars software as opposed to making physical changes?
Old 07-04-11 | 12:06 AM
JoshIS408's Avatar
JoshIS408
- - G T V I P - -
Im sure it would be more specific if you searched nav hack . im sure all your questions and answers will be in that thread(s)
Old 07-04-11 | 02:48 AM
Kurtz's Avatar
Kurtz
The only software override there ever was was on the original 2006 models if they never upgraded their firmware.
Everyone else needs to either cut wires or buy the $300 plug and play version (that does the same thing as the wire cut without cutting, but you still have to take the dash apart to install it)
It's a "safety feature" and reason 729 I avoided the terrible factory nav system in favor of a garmin.
If they had to put in an in-motion lockout a much smarter way would be to tie it to the same sensor that turns the passenger airbag on/off when it detects you having a passenger or not... no passenger- it's locked out in motion... passenger? not locked out.
Old 07-04-11 | 07:31 AM
Seabee1986's Avatar
Seabee1986
Thanks for the help guys. I'll do some research and see what I can find
Old 07-04-11 | 09:28 AM
pepos's Avatar
pepos
http://www.visualpoint.net/lexus
DIY with photos
The only hard part is removing the central airvent
Nav DVD Bluetooth bypass.
Old 07-04-11 | 01:49 PM
98023IS250's Avatar
98023IS250
Display
Turn off...
Old 07-11-11 | 05:16 AM
Seabee1986's Avatar
Seabee1986
DIY with photos
That was an awesome write up but unfortunately it was for pre-2007, this one is a 2010.
Thanks anyway!
chi123
09-26-14 05:36 PM
greener143
06-22-14 02:23 PM
PH1958
03-09-10 05:40 AM
BklynJay
01-11-07 10:14 PM
