S2k tips no GFX
I've seriously considered these tips and I'm glad you posted pics. I'd say overall they look very good. But like how I saw once in person, I don't like how much the sides show. They seem too long, even when you mash them in all the way. Mercedes tips are like this too and it reminds me of cheaper aftermarker tips you find at auto parts stores. My goal would be a pure OEM look, but with a thicker rim and slightly larger overall. Still haven't found something like that that didn't have the long sleeve or pipe look.
Looks pretty damn good. I was thinking about these as well.
Are you going to be able to easily remove them? Since they needed to be smacked on? I'm scared I'd get them on there, hammer and they would turn a bit and I would be stuck.
I mean they are on there pretty good but you can always get a 2x4 wood chunk wedge it against the back side of the tip and beat them off and slide your stock tips back on. It will probably take some effort but it's defiantly reversible.
I'm sure I will wake up one day and it will hit me that I need a GFX rear lol but as one of my earlier posts said I'm really in the market for a front lip which I don't think they make yet for the 2011 front bumper.
Well the trick to get them to slide in up against the muffler pan. But to do that you need to bend a little bit of metal. First off if you notice when you slide off your stock tip that on the muffler pipe itself there are raised ridges in the metal to hold the clips on the stock tips in place. You need to get a decent set of pliers and bent them all in until they are as flat as they get. Next what I did was slide the s2k tips on and force them on a little to see where they scrape and get stuck. What I had to do was use the pliers to make the overall diameter of the actual exhaust pipe a millimeter smaller to get the s2k tip to slide on, which still will require a decent amount of force. After I used a 3LB rubber hammer, but before you start beating the tips with the mallet be sure you get them on straight and keep them that way because there is no adjusting them after that. If anything just pm me, I'll be happy to help you as much as I can. (Not sure if the explanation above is clear enough lol)
