Satellite Radio
Yes, I did the install. If you follow this:
https://www.clublexus.com/forums/is-...o-install.html
it's not all that bad or difficult.
Please let us know how that site is. That was the only place I did a search on that had both pieces for the XM Radio.
nobody believes me when I tell em stuff is discontinued ![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
Anyway, you might be able to rig something up... here's a guy who used the wiring diagrams to make the IS adapter work in his ES (as their kit was discontinued even earlier)
https://www.clublexus.com/forums/es3...rk-around.html
so you might touch base with sewell or look over the attachement there and see if you (or some friend good with wiring) could rig something up to make it work.
I'd add that you might mention to said guy that selling these online would make him a few bucks since it's a part otherwise not available anymore and there's more than a few folks who'd like to still be able to buy it.... might make him more considerate in his pricing to make yours
Merkur Fanatic
I bought a used 2008 IS 250 and added an iPod dongle but now would like to add Satellite radio but when I push the SAT button, it goes to SAT1 and the word deactivated shows on the top line. Is it possible that the dealer had to deactivate the Satellite radio to connect the dongle and that I can't have both?
Thanks.
Thanks.
Registered User
On the old style Lexus XM radios. You have to use a Y shaped cable. So you only have one input. So its the XM wiring or the iPhone. But not both.
You need to go with a Vais adaptor to get all the inputs you want. Its a box where you hook up everything to. Then connect it to the radio.
Thanks.
Thanks.
The Lexus ipod adapter doesn't work with the factory XM tuner.
If you have the factory XM tuner (which isn't available anymore) I'd highly suggest you remove and sell the ipod adapter then buy a better aftermarket one that doesn't use the SAT port (VAIS and others sell them).... the factory XM tuner is a better integrated experience than any aftermarket one.
Kurtz,
Thanks much for your reply. As a follow up...Is there anyway to detrmine whether I have the factory satellite module installed, or not? Hopefully without taking the whole radio out.
The fact that the display goes to SAT 1, 2 and 3, leads me to believe that I may have it but since it doesn't show a radio ID# I am really not sure.
Thanks.
Thanks.
Kurtz,
Thanks.
Thanks.
I have Sirius xm on one of my cars, and just bought used GX with expired subscription. Radio only receives the 000...promo channel and is offering 6 months for $30. My question is, if you use a car, primarily seasonally vacation travel, such as April thru Sept....can you cancel and then renew. That is how I used the Internet TV service Sling....I just close it ...they stop billing, then go online to open back up. Can I so this with Sirius?
