How far have you driven on empty?
There's been several threads on this topic already.
But as to the fuel pump (also covered in those threads)-
In older cars it was a bad idea to run much below 1/4-1/8 of a tank for this reason.
Since at least the Mk4 supra though Toyota/Lexus have used a system where the pump sits in a small sub-tank of fuel, such that you can run considerably lower without risk of overheating the pump. (and you'll find a diagram of this if you check one of the other threads on this)
THAT said, there'll still be a "too low" even for that system, and I'd say when you hit 0 on range you're probably about there, despite the fact you can likely go another 40-60 miles before needing to push the car.
This question is easy for anyone to answer him- or herself. My 2007 IS350 has a fuel tank capacity of 17.1 gallons. I get on average with my driving about 24 MPG. When my display's range hits 0 miles and I go to fill up, I find that I fill up about 15 gallons. That means I had about 2.1 gallons left in the tank. 2.1 gallons x 24 MPG = 50.4 miles left to go until truly empty.
Just follow this reasoning on your own car and you'll get the answer you're looking for.
I obviously try my hardest for this not to happen but it has 2x.., I've gone around 35-40 miles after 0 no issues. Even @ the fillup from those I have only maxed 15.8 @ the pump so maybe I still had another gallon or so left. I wish prem gas wasnt in the still around $4.50 here in Eastern Long Island, making me have to dry all normal and stuff..
Yep panicking is no bueno mijo! I almost thought I was going to have to call for the tow truck and my friend at the time was scared as hell because we were on a backroad in the middle of nowhere NC. She almost made me lose it, until I ran into a perfectly nice town (again in the middle of nowhere, NC) and was able to fill up.
I don't pay attention to the fuel light. I've learned that when the miles remaining hit 0 there is atleast 2-2.5 gallons remaining in the tank. I've driven an additional 40 miles when the miles remaining hit 0. I've then filled up 16.5 gallons. I always get about 370-380 miles out of each tank.
Wow, I cant believe so many people have gone beyond 0!!!
I normally dont even let the gas light come on but the other day I was 100 miles from home and the tank said it had 82 left. I didnt feel like stopping so as I drove I watched the two numbers get closer, finally when I got off at my exit it said 3 miled left in tank and 4 miles to home. When I got to the gas station a few block from my home it still said 2mi left on tank.
I was only able to put in 16.01 gallons even after topping off 10 times, owners manual says we have a 17+ gallon tank so I was probably good another 20+ miles because I generally top-off pretty good.
I've driven to work on 0 approx. before (about 25~ miles). I was running late for a meeting, so I didn't have time to stop by and get gas. I think I filled up like 16 gallons afterwards though.
I know a lot of people who start to panic and fill up immediately when their gas light turns on, and I keep trying to tell them they still have several gallons to go til they're completely empty, but nobody listens.
I mean, from an engineering standpoint, you always want to have a good safety buffer for everything. Making a gas light turn on right before you run out of gas doesn't seem like a good design. That's not a big enough safety buffer...The light turns on to let you know you need gas soon, not immediately.
