what can i do? HKS hi-power turning my white vertex lip yellowish
hey guys, wondering if any you had and have a solution for this problem. im running hks hi power exhaust and a vertex rear lip. my car color is starfire pearl and its starting to turn the area where the tips are abit yellow and brown. its the smoke coming out.
is there a solution for this. it will get worst.
it's either the heat from the exhaust system or the hot exhaust gases that is/are heating the clearcoat and causing the discoloration.
i had the same issue w/ my GFX rear lip and HKS hi-power, and it eventually became a noticeable light brown haze around the exhaust outlet.
unless you can find some way to restore the clearcoat on your vertex rear lip, i'd say it's somewhat permanent and will require a re-spray of your rear lip.
