Crap i think i made a mistake! [installing spoiler]
So when i installed my ebay spoiler, i realize there was tape there already from the spoiler, but i put more 3m tape on top of that! now you can kinda see the tape in the crack.. The spoiler has been on for about 3 days now, I mean it still looks good and all and not really noticeable unless if you walk directly up to it and stare.. also from the back side you cant tell at all..
you think i should take it off and redo it? Is that even an option?
Not sure I understand - did you put tape on top of tape?
It's not the fault of the tape, its the fault of the poor fitment of the spoiler. :/
When it comes to applying tape, make sure you have a single strip running the length of the underside of the spoiler. That way it looks uniform with no gaps. And use as much tape as you like to ensure it doesn't come off.
You can remove & reapply as often as you like, but you'll need some adhesive remover to save time and hassle.
heat it up and slowly pull then use goopoff for any adhesive left behind.
give somthing like this a try
http://youtu.be/5saNP7cdFck
