ElectroLuminescent Gauges not spinning on startup.
Old 07-30-11, 12:30 PM
Stun350
Stun350's Avatar
Default ElectroLuminescent Gauges not spinning on startup.
So I've noticed that my gauges have stopped spinning like they used to from base to tip upon ignition. They operate fine once the car is on though. Should this be cause for concern? My car i still under warranty.
Old 07-30-11, 01:29 PM
MrBBQ
MrBBQ's Avatar
Hmm.. it suppose to do that in the on position and startup (everytime the gauges turn on). If it stops doing the needle sweep, take it in while its still under warranty. It's weird you said it works fine after the car starts. There isn't a way to turn it off as far as i know. I'm so used to it I don't even notice it anymore. My friends love it though. They think its cool whenever they see it.
Old 07-30-11, 02:20 PM
Stun350
Stun350's Avatar
THanks for the input. Yeah I like the effect it produces too. It looks pretty cool. Sometimes the needles sweep and other times they don't. There's also an uncharacteristic flash right as I press the start button to turn the car on. I'll make sure to let them know at the dealership as my car is due for 35K service.
Old 07-30-11, 06:09 PM
ecr527
ecr527's Avatar
I don't know if it was just a coincidence, but my car started doing this too, and it just happened to be around when I needed to replace my battery. After I replaced my battery, all was good.
Old 07-30-11, 07:54 PM
Defender46
Defender46's Avatar
Sounds like you should get the battery checked or something in case there's a bigger problem, definitely don't want them to stop working all together after warranty is up!
On the bright side you don't have them making the grinding noise some have noticed on startup
Old 08-03-11, 08:26 PM
Stun350
Stun350's Avatar
Well it happened to be the battery. I asked them to test the battery and it failed so they replaced it for free. Thanks you all for the input.
Old 08-03-11, 08:47 PM
nsxiboi
nsxiboi's Avatar
OH wow... I just noticed this recently also. I guess i gotta get my battery checked...
Old 08-04-11, 12:32 AM
my1s250
my1s250's Avatar
what battery the car battery????
Old 08-04-11, 08:43 AM
Stun350
Stun350's Avatar
Yes the car battery.
Old 08-04-11, 10:23 AM
mikeho
mikeho's Avatar
Now that's an awesome interface! What a crazy way to know that your battery has problems by the needles not sweeping. I'll have to remember that for next time...
Old 08-04-11, 01:37 PM
Stun350
Stun350's Avatar
Yes I know. Here's a link to the video where that shows what was happening at startup.
http://www.youtube.com/watch?v=F_VJCywnZXg
Old 08-04-11, 02:05 PM
allst4r
allst4r's Avatar
yea same thing use to happen to me got the whole inside dashboard replaced. under warranty and now it started happening again 2 years later.. sucky thing is im out of warranty now.. i just live with it. and pray its not a engine issue.
Old 08-04-11, 02:31 PM
KillaIS250
KillaIS250's Avatar
^ It's not an engine issue. They are entirely different lol.
Old 08-06-11, 10:52 AM
codenko
codenko's Avatar
its probably a battery thing like the OP...my moms acura used to flicker the gauges before starting and stopped doing that once we replaced the battery
ybing
LX - 3rd Gen (2008-2021)
02-09-16 11:02 AM
redliner8
12-09-10 01:33 PM
gsean400
01-08-10 02:06 PM
jimjaix
11-20-07 11:13 PM
el3ctone
05-26-07 11:50 AM
Quick Reply: ElectroLuminescent Gauges not spinning on startup.
