Car stuttering at stop light then warning lights turn on
Old 08-02-11, 09:53 AM
andyboy
andyboy's Avatar
Default Car stuttering at stop light then warning lights turn on
I was driving my wife's car lastnight and was stopped at a light then noticed that the car was stuttering like it was about to shut off. The light turned green so I pressed the gas and then the VCS, engine and the red (!) light came on. So I pulled over to turn the car off and back on and the issue went away. When I came home I checked the intake and it was fine. Not sure what else to look for but this happens every so often. And of course the car is out of warranty. Any ideas?
I know if I take it to the dealer they will say "can't reproduce the problem" or give me some BS that will cost $$$$ to fix.
Old 08-02-11, 10:11 AM
650IS350
650IS350's Avatar
I'd check for loose hoses. or what others have mentioned on similar threads, throttle body cleaning?
Old 08-02-11, 10:16 AM
wntrwhte
wntrwhte's Avatar
This sounds to me at first glance like possibly a dirty idle air control or similar.
Is the battery original to the car?
Old 08-02-11, 10:21 AM
andyboy
andyboy's Avatar
Brand new battery. It was changed about 3 weeks ago. It also happened with the original battery as well.
Old 08-02-11, 10:38 AM
embolism
embolism's Avatar
search for carbon buildup issue
Old 08-02-11, 11:56 AM
SPNinjA
SPNinjA's Avatar
When I first purchased my car (used) it happened to me a couple of times minus the warning lights. I did a little research and carbon build up seems to be the culprit. All I do is WOT every once in a while and so far, I haven't ran into the stutter problem.
Old 08-02-11, 01:46 PM
calvin2376
calvin2376's Avatar
Carbon build-up.
Old 08-02-11, 02:01 PM
andyboy
andyboy's Avatar
how can I remove the carbon build up?
Old 08-02-11, 02:12 PM
2slixx
2slixx's Avatar
Also can happen if you pump 87 octane... the engine pings while idle or stopped.
Old 08-02-11, 02:27 PM
shadowman
shadowman's Avatar
If your car is still under warranty, have them perform a top cleaning service under the TSB. You can ask for this service done, but it won't be cheap. The need to open up the engine to really clean the gunk.
Just dumping fuel injector cleaner in your gas tank won't do you any good.
This is a common issue with direct injection engines like IS250.
The carbon build-up thread has more details on it. Just do a quick search...
Old 08-02-11, 02:56 PM
Sffd103
Fire Slayer
Sffd103's Avatar
I just took my car in for the pedal, fuel pressure, and rough idling......they did the "Top Engine clean." Just tell them that it was hesitant and sputtering at the light and they'll hook it up and see what codes came up if any. Do it before warranty is up. Runs smoother also. I also had my plugs changed (bought through Sewell) while they did this since they have to open it up anyway. Also had synthetic oil put in( bought at Costco Mobil 1) and bought the oil filter at Sewell also. Total charge......FREE!!!!! They may charge you 1/2 hour labor to do plugs though. I had a hook up, but try it. Good luck!
Old 08-02-11, 03:22 PM
andyboy
andyboy's Avatar
You mean the powertrain warranty? Or the full coverage warranty? Cause it's out of the full coverage warranty.
Old 08-02-11, 05:48 PM
calvin2376
calvin2376's Avatar
The 70k powertrain warranty covers this TSIB.
This should answer all your questions: https://www.clublexus.com/forums/is-...d-threads.html
Old 08-02-11, 06:37 PM
SteveTango
SteveTango's Avatar
LOL! When I saw WOT... I was like Woman On Top??? LOL!!!
Sorry had to mention it, can't help myself.
Old 08-02-11, 07:34 PM
DenIS250
DenIS250's Avatar
^lol...so what does WOT means?
Quick Reply: Car stuttering at stop light then warning lights turn on
