Help me Bust this shop
Long story short, I took my car in for speciality alignment and oil change yesterday. It took them about an hour to finish the job. The speciality alignment is specifically for lowered cars, and the first rep I spoke with told me it would take at least 90 mins itself.
so when I was paying for the service, I asked them for the report of my alignment, they told me their printer is broken, i was like ok...
and when I got in the car, the oil maint required alarm is still off, so I thought maybe they did change the oil, but just forgot to reset the sensor
lastly, they tried to charge me labor for a service i wanted to do, but later on I decided to cancle..
with all these things happening at once, I can't help but jump to the suspection that since my car was the last car they were working on, they pretty much just took my car in, left it there for an hour without performing any work on it, and took my money.
So i really want to find out if this is the truth, for my money and my car's sake. Therefore, are there any easy ways for testing if they have changed my oil? I know they are supposed to replace the oil filter while doing the oil change, maybe I should check that?
Any thoughts guys?
Thanks in advance for your help.
Any thoughts guys?
Super Moderator
Our car has a canister oil filter, only the paper element inside a permanant housing is replaced.
Checking the filter isnt practical, you'd need a new one or at least an o ring. If you're going to double check oil changes you should do it yourself. Just check the dipstick and see if its clean, when you go to an independent shop they don't usually reset the reminder, or even notice its on-really easy to reset yourself. Unless you JUST finished lowering your car and have a bunch of adjustable links added there's no way the alignment will take 90 minutes. If you haven't changes any links then only front and rear toe is adjustable and it should take an inexperienced tech about 35 minutes max. They probably say 90 minutes in case they're busy and can't get to it right away. Maybe they did the service before you changed your mind - who knows on that one.
As to the other service, I asked them to raise the car up about 3 rounds because I was too lazy to do it myself in this 110 weather, but i realized i didn't bring the wheel lock, so there is no way they could have done it.
