Anyone swapped heated/cooled seats in a non heated/cooled equipped IS?
Anyone have any resources or knows if it's possible to swap seats out to the heated and cooled seats?
I realize I'll need the center dash trim and the center dash dials that control the seats but is there anything else?
Would I also need to get the memory seat panels on the doors? I don't care to have memory seats but if that's what's needed to do the swap correctly then I'll try and find a totalled out IS at a junk yard and pull all necessary items.
Hopefully I don't need to pull the the ECU or anything.
TIA
TIA
search my user name. fluxx, made a userguide somewhere on the forums. you just need the seats, on/off swithc and one of the modules...
its doable, cause i did it, but 100-150 bucks for the 2 pieces, swithc and controller modules and the seats are a crapshoot. seen them anywhre from 200-1000 for a set
https://www.clublexus.com/forums/is-...-your-car.html
Thanks Flux.
