Not using same gasoline brand regularly... Problems?
There's an ethanol free station within a couple miles of my house that I tried for 4 or 5 tanks. I might have got another 1 mpg increase but it cost $.30/gal more than premium elsewhere plus they only take cash. At first I thought it might pay for itself but doing the math it just didn't add up. If it had been 3-4 mpg, maybe. Wasn't worth it so I switched back.
Super Moderator
In the Augusta, Ga area, we do have a couple of small independent stations that advertise non-ethanol fuel. I've tried it several times, but as anthrax144 said, the difference seems very slight compared to the 30-40 cent difference in price.
None in NJ but plenty in SC. Not sure where Grand Strand is but check the list.
So how does that math "add up" to an actual savings?
As long as the gas stations are part of the top teir gas, then there is nothing to worry about in terms of usnig different stations.
http://www.toptiergas.com/retailers.html
Going back to Chevron, the fuel economy was up a bit.
Well man if $2 a tank is a "big deal" to you maybe you should consider owning a less expensive car to operate such as a leaf/prius/volt etc....
Lexus clearly states to use PREMIUM UNLEADED FUEL. Maybe you could run your oil for 10,000 miles then filter it yourself with a coffee filter and re use it, that would save you some money also!!!
If you can afford a Lexus you should be able to afford to operate/maintain it.
I can afford to buy a Porche 911... why dont i have one you ask??? cause i cant afford to pay a mechanic a full time salary to work on it.
