Ok so who hasnt gotten the fuel sensor recall done?
I havent noticed anything out of the ordinary... I dont plan on going to the dealer anytime soon, too far away.. waste of time.. I drive past the dealership everyday on my way to work but I purposely forget to stop by haha
My car suffered a failure of the gasket in question by this recall about 1 week before the recall was issued. I started smelling gasoline both inside and outside the car. Turns out it was leaking into the engine bay. This could have caused a fire or explosion. I took it into the dealer, they gave me a loaner, one day later it was fixed and I was on my way, with no problems since.
Go get the work done. You're more likely to suffer from a failed gasket and have a potentially dangerous situation result than you are to have a dealer somehow ruin your car and not fix it/make you whole.
At the very least, do it for resale. I personally would skip over a car that had open, unperformed recalls from several years ago. It's the clearest indicator that the owner doesn't care about the car, doesn't treat it well, and doesn't keep up with maintenance and repairs. If an owner doesn't go in for a free recall, clearly he isn't going to go in for less serious things (failed navigation, dash rattle, aux-in noise) to get them taken care of.
You believe yours does not need it? Pardon me if I trust the people who designed, manufactured, and tested the car over you.
You may be right that your car is not currently suffering from a failure of the part in question. And you may be right that your car never suffers from it for the entirety of the time you own it. But why risk it? It's a free recall, you get a loaner car, and they give you a free tank of gas. Furthermore, keep in mind that if you wait and some while down the road this issue does occur and causes damage to your car and you're out of warranty, you'd better believe it's going to be out of your pocket to repair it.
guess you didn't notice I said 4 "recalls" :-)
Safety Recall BLA Certain 2006 - 2007 GS, 2006 - early 2009 IS 250 and 2006 - early 2008 IS 350 vehicles Insufficient Tightening of the Fuel Pressure Sensor
Safety Recall ALG - Certain 2006 Model Year Lexus IS and GS Vehicles & Certain 2004 through 2006 Model Year RX Vehicles Brake Master Cylinder Cup Replacement
Safety Recall ALE - Certain Lexus GS 350, GS 450h, GS 460, IS 350, LS 460, LS 460 L, and LS 600h L Vehicles - Valve Spring
Safety Recall 9LG - Potential Floor Mat Interference with Accelerator Pedal
You should really get it done to avoid any problems in the future. I got mine done, didn't noticed any difference as mine just needed to be tightened. I got a free $64 tank of gas and only took 3 hours. I didn't get a loaner car since it was only a few hours plus I'm not old enough to be given a loaner.
There's the chance yours is probably good but not worth it just because you don't want people touching your car. You're going to need to bring in your car for repairs some time in the future anyways.
