Power Tilt/Tele Steering Wheel Reliability?
Hi folks,
The other thread on the power tilt/telescoping wheel got me thinking about something. I bought my car a few months ago, and the previous owner had their LPS set to move the steering wheel every time the car is started or shut down. I probably average about 4-6 start/shutdown cycles on my car daily.
Has anyone had any long term issues with the power tilt/telescoping steering column and having it auto-tilt upon engine start/stop?
try this, set one of the memory positions to match the "top" position of the wheel when the car is off. Then when you don't need the wheel to be telescopic/tilt, use that button and the wheel wont be going thru the cycles. This sorta lets you control this LPS dynamically. I did this in my car for those times that I'm in/out of the car super-frequently
electronics dont fail on them in any lexus. will just make noise. lubricate gears and any moving parts with Toyota body grease. its about $35 for a lip balm size grease but works flawlessly and no mess. its same color as lip balm
Thanks for the responses, guys! I guess I grew concerned when I read of some power mirrors failing from daily use of the reverse-tilt feature, but I guess there's no need to be concerned.
Awesome, thanks for the tip!
Very clever.
Maybe to clarify (or correct myself), by "set" I mean, "he didn't change it," although there are some settings on my car that differ from default, implying to me that at some point he would have had the LPS settings changed and would have had to review the steering wheel option.
I have an '06 that was purchased in December 2005, have many drive cycles a day, and it is still working fine. I have noticed that the past few years, when the car is parked outside all day in the hot sun, that the mechanism does make an annoying noise when it is moving the wheel into position.
Now, each time the car goes to reverse, when the mirrors tilt back up, they keep going ALL THE WAY UP, until I adjust them with the switch. I can put the rocker in the middle to make it stop.
BUT--it does the same thing when I open the car because my fob is tied to the memory. I tried cancelling the memory--but the cancellation is not working. so every time I unlock the car, the mirrors point up to the sky and keep trying to adjust upward.
PLEASE HELP!
