So yeah I'm an idiot, I changed my D4S bulb and I was in such a rush I forgot to put back on the little door, now my headlight has little running water and foggy inside. How do I fix this? fml...
hmmm sounds like you're using the wrong bulb causing the flicker... use a heat guy not a blow dryer cause the water will never evaporate fast enough.. after drying let the car sit overnight and double check it the following morning.. better to park it in the garage
