Acceleration on 2008 IS 250
Old 08-16-11, 10:23 PM
itsjamin
itsjamin's Avatar
Default Acceleration on 2008 IS 250
Hey guys!
I'm new to Club Lexus and this is my first thread that I've created! But I have a question about acceleration on my car. I've noticed that when I'm at a stop and I step on the gas pedal, there is a slight lag in terms of power going to the wheels. When I drive my girls car, which is a 2007 IS 250, you can feel the response right away once you step on the gas. Is there a reason for this? Were the 08 models different than the 07 models in terms of engine builds? Any help would be great! Thanks guys!
Jamin
Old 08-16-11, 10:26 PM
patrick323
patrick323's Avatar
Interesting. I'm curious to find out what some people have to say. Wish I could offer some ideas.
Guess i bought the right year If it is a product of the design then perhaps one of those throttle controllers would be of aid.
Old 08-16-11, 10:29 PM
itsjamin
itsjamin's Avatar
I hope that there is an answer for this but how much do those throttle controllers go for? Is there an adjustment for these if any? Thanks again!
Old 08-16-11, 10:41 PM
patrick323
patrick323's Avatar
I'd like to think that there is something awry that can be fixed. i wouldnt think that there would be a decrease in acceleration/response between 07 and 08, especially for the worse. So obviously wait until you consider a throttle boost controller thingy-ma-bopper.
I dont think they cost much. They just trick your computer into thinking you're pressing down the gas pedal harder, essentially.
Old 08-16-11, 10:50 PM
Sango
Sango's Avatar
What mode are the cars in (normal, Power)?
I've driven a 2007 AWD and 2008 RWD. The response is the same, I do not sense a difference.
With the nature of the electronic throttle, there will always be a delay (as compared to back in day when mechanical was used - this was instant), never instant. In the Lexus cars anyways, there is about a quarter sec I believe (user input to action). I tried Subaru's car before, throttle delay too long, about 1/2 second!
Old 08-17-11, 12:39 AM
Fizzboy7
Fizzboy7's Avatar
I have an '08 and I don't feel any lag at all. I keep it in POWER mode, but even without that on, there's still no lag (just less power). I've also driven the 2006 and 7 and didn't notice any there either. Might be something with your particular car (?).
Old 08-17-11, 12:49 AM
llamaboiz
llamaboiz's Avatar
You need to reset your ECU as it has 'learned'. Goto the sticky FAQ to learn how to do this.
Old 08-17-11, 12:51 AM
SDgoods
SDgoods's Avatar
The ecm will actually 'learn' your driving habits and style. A vehicle that is driven harder will have higher shifting points and better response then a grandma driving. Perhaps this could explain what you're experiencing
Old 08-17-11, 12:52 AM
SDgoods
SDgoods's Avatar
O man u beat me to it slow typing on this phone!
Old 08-17-11, 01:00 AM
Caliguy350
Caliguy350's Avatar
Try using fuel injector cleaner!!!!
Old 08-17-11, 06:05 AM
TheSenator
TheSenator's Avatar
I have come from some American sports cars (torque monsters) where I can see the lag in the 250's accel response. I think it depends on the gear you're in as the transmission tries to accomplish the accel smoothly.
The Power ECT option would probably help this a little bit I think, but throttle controllers don't deliver the power faster they send a false signal to the ECU that you are pressing the gas pedal down FARTHER than you are, but not faster.
IE- If you depress the pedal 50% it sends a signal saying you pressed it 70% or whatever the ratio is...
Resetting the ECU is a good place to start as stated above!
Old 08-17-11, 07:32 AM
Sango
Sango's Avatar
I believe Kurtz may know better about power and normal mode since he had his input in the power/normal mode thread a while ago.
Old 08-17-11, 08:09 AM
iRock
iRock's Avatar
Your girl drive/ aggressive? If so trying to reset is probably your issue.
Old 08-17-11, 08:21 AM
KillaIS250
KillaIS250's Avatar
I'll make it even easier for you, here's the thread on resetting the ECU...
https://www.clublexus.com/forums/is-...k-service.html
(just go down a bit and there's instructions)
Old 08-17-11, 11:21 AM
Kurtz
Kurtz's Avatar
ECT-Power does nothing at all in 1st gear, so "from a stop" it doesn't help at all. See also:
https://www.clublexus.com/forums/5807368-post24.html
I agree with the reset the ECU advice as a first thing to try.
Quick Reply: Acceleration on 2008 IS 250
