windows not rolling down
Old 08-17-11, 01:24 PM
tjschraf
tjschraf's Avatar
Default windows not rolling down
I have a 2006 IS 350 and my rear window will not roll down from my drivers seat controls. but it still rolls down if you are sitting in the back and try to roll it down. But the automatic up and down does not work at all.
I just got it fixed from minor scratches on the drivers door, drivers rear door and above the wheel, could it have been the problem that possibly they did not hook it back up? has anyone had a problem like this?
Old 08-17-11, 01:29 PM
kumquatism
kumquatism's Avatar
Sounds like the battery was disconnected.
https://www.clublexus.com/forums/is-...isconnect.html
Old 08-17-11, 01:54 PM
KillaIS250
KillaIS250's Avatar
Definately check ^^^ link first and see if it fixes your problem. 99% of the time its that lol
Old 08-17-11, 02:53 PM
baypistol
baypistol's Avatar
I had the same problem and the dealer showed me how to solve this. He rolled the back driver's side windows down from the back passengers seat first and held the button down and then roll it back up, then the back passenger side. This would reset the computer. When I tried to control the window from the drivers seat again, it worked after. They go out of electronic alignment.
hfbldpnce (01-10-22)
Old 08-17-11, 03:07 PM
rich250x
rich250x's Avatar
^+1 this happened to me a couple weeks ago and did this and it worked again
Old 08-18-11, 11:58 AM
brociouz
brociouz's Avatar
It doesn't matter what order you do it in, you have to reset each window control individually. All you do is roll the window down (just a little, doesn't have to go all the way down) using switch on the door then roll it back up and hold for 1 second. You'll hear a small click sound. The lights also flash on the window control switch to indicate they need to be reset.
Old 08-18-11, 12:11 PM
whitebeast
whitebeast's Avatar
you have to do it every single time you disconnect power of your window control ( change battery, or swapping window control switch ...)
Old 08-18-11, 12:15 PM
tjschraf
tjschraf's Avatar
thanks for all the advice, for what ever reason... my window started to work today when i got in my car. I must have subconsciously done the protocol
texves
06-11-15 06:57 PM
SpmMorrow
IS F (2008-2014)
07-11-12 11:01 PM
CorbinD
Hybrid Technology
03-26-10 03:47 PM
Slick_Rick
05-16-08 12:25 PM
Ramon
05-31-06 01:17 PM
Quick Reply: windows not rolling down
