Success: Installed an IS300 Torsen LSD in my IS250
Old 08-21-11, 04:18 PM
projectdna
projectdna's Avatar
so going off of Gville350's earlier post...
given this:
Originally Posted by Jeff Lange
06-11 IS350 and IS F models have a 208mm rear differential
and this:
For the IS F:
2008-09's do not have an LSD.
2010+ has a Torsen.
(theoretically) a torsen rear diff from a 2010+ IS-F would fit the 06+ IS350, right?
Old 08-21-11, 04:23 PM
MyIS350G
MyIS350G's Avatar
wow nice! good job!
Old 08-21-11, 04:35 PM
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
Correct, but you'd just use the Torsen and put it into your existing case, as the IS F has a different case and subframe bushings, plus the gearing in the IS F is 2.9:1 versus the 4.1:1 in the IS350. You would not want IS F gearing in an IS350.
Jeff
Old 08-21-11, 10:25 PM
Lexus@17
Lexus@17's Avatar
wow this is a pretty big break through!! going to be useful for anyone wanting to do a 2jz swap!
Old 08-22-11, 06:02 AM
B16da9
B16da9's Avatar
Congrats on the successful swap, this is for sure my next swap and like you I would want an Auto IS300 LSD for faster of the line acceleration.
Old 08-22-11, 06:20 PM
Gville350
Gville350's Avatar
True! So if that's the case could the ring gear easily be transferred from the 350 to the 2010+ Torsen LSD? I assume the half shaft inputs (spline count) are the same as that of the 350?
Old 08-22-11, 06:40 PM
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
IS F and IS350 use the same rear axles. You should be able to fit the IS F LSD into the IS350 case using the IS350 ring gear.
Jeff
Old 08-22-11, 07:00 PM
Gaugster
Gaugster's Avatar
Very cool indeed. Now who is gonna do the posi-trac mod'???
Old 08-23-11, 05:30 AM
B16da9
B16da9's Avatar
This thread gets five stars.
Jeff, thank you for being using your car as the genie pig for other 2IS owners.
Old 08-23-11, 06:57 AM
Kurtz
Kurtz's Avatar
Jeff
I'd be surprised if you could do it for less than just buying an aftermarket posi though.
Isn't a new IS-F diff north of 4 grand? (it's not like you'll find a bunch sitting in scrap yards given how relatively few Fs are sold at all)
Old 08-23-11, 07:14 AM
jtamulis
jtamulis's Avatar
Heya Jeff Lange, isn't that the same Spec as the MKIII Supra diff? It sure looks like one to me. Lots of IS300 guys are trying to get Supra Diffs off me to stuff in the IS300.
Jeff
Old 08-23-11, 10:52 AM
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
Yes, you could use the A70 Supra diffs in the IS250 as well.
Jeff
Old 08-23-11, 11:23 AM
Gville350
Gville350's Avatar
But of course. But when say 5 yrs down the road this might be helpful to someone. If anything, I'd probably go with another Quaife. Had good experience with the one I had in my Honda with 400+ whp.
Old 08-23-11, 11:39 AM
B16da9
B16da9's Avatar
Jeff
So the MKIII supra diff will bolt right up to the IS300/IS250? If so I can find this very easly localy.
Old 08-23-11, 12:52 PM
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
Yes, but remember that the MK3 Supra diffs are clutch type and 20 years (at least) old, they're probably quite worn by now, so you'd likely want to overhaul it before installing it.
Jeff
Quick Reply: Success: Installed an IS300 Torsen LSD in my IS250
