Success: Installed an IS300 Torsen LSD in my IS250
#37
I will likely try autocross next year when I get some new tires and suspension. Until then I'll just been enjoying it through various corners in the city and mountains.
I've driven the car quite a bit more since I first installed it, and it is a noticeable improvement through "spirited" cornering.
Jeff
Jeff
#41
Just wanted to add one more door jamb code here:
B02C also means there is an LSD and I will ASSUME B02B as well if that exists, since both B and C = LSD. The LSD I got was from an auto 2001 IS 300 and the 02 means the E-Shift gearbox I believe. It is also 3.91:1.
#44
Umm did you not read the first post?
"06-08 IS250 AWD models have a 190mm rear differential (A Torsen from an IS200/RS200 Altezza might work well in this application)
06-11 IS250 RWD & 09-11 IS250 AWD models have a 205mm rear differential (The IS300 Torsen is a bolt-in upgrade for this application)"
...lol
...lol
