Success: Installed an IS300 Torsen LSD in my IS250
Old 03-09-18 | 01:35 PM
  #106
NorthernIS's Avatar
NorthernIS
That probably why the guy uses a hammer. 😶 Here's a interesting link http://www.fourwheeler.com/how-to/transmission-drivetrain/1507-can-you-install-your-own-gears-at-home/
Old 05-18-18 | 12:53 PM
  #107
Austin32's Avatar
Austin32
Hi how can you remove the differential from the car without pulling the axles from the hubs? I dropped the differential from its mounting points but could not get the axles out of the differential. Any help would be appreciated gt86 differential sitting on the bench waiting to go in! Thanks.
Old 05-18-18 | 02:54 PM
  #108
Gville350's Avatar
Gville350
You won't be able to remove the diff from the carrier unless the half shafts are removed from the carrier as well. The stubs of the half shaft stick into the diff there.
Old 05-18-18 | 04:57 PM
  #109
Jeff Lange's Avatar
Jeff Lange
Keeping it Real
If you drop the differential and twist it just so, from what I can recall, it is possible to get the axles out without disconnecting anything else. It is a big pain to attempt this. The better way to go if you don't want to remove the axles from the hubs, is to undo the lower control arm bolt, giving you room to move the knuckle outwards and get the inner to pop out from the differential case.
Jeff
Old 05-19-18 | 03:31 PM
  #110
2013FSport's Avatar
2013FSport
Jeff
Just posted this same thing in his other post. https://www.clublexus.com/forums/is-...ial-is250.html
I'd imagine one could do just the one side if they wanted too.
Just remember to put the car back on all fours before tightening any rubber bushing pivot points or you'll destroy the bushing from over rotation once its back at normal ride height.
Old 05-19-18 | 03:56 PM
  #111
2013FSport's Avatar
2013FSport
Originally Posted by NorthernIS
That probably why the guy uses a hammer. 😶 Here's a interesting link http://www.fourwheeler.com/how-to/tr...gears-at-home/
^^ Good basic info in that link. Nice find.
IS-F is the same install as the 350... A couple links w OS Giken LSD. They sorta went nuts pulling the axles but oh well. Its just nuts and bolts and likely went quickly on the lift. See pictures.
http://figsengineering.blogspot.com/...-lock-tcd.html
More detail on the same install as above.
http://figsengineering.blogspot.com/...tallation.html
Old 05-21-18 | 10:12 AM
  #112
Austin32's Avatar
Austin32
thanks for the replies guys
Old 05-21-18 | 05:17 PM
  #113
JETLEX's Avatar
JETLEX
Not sure if this helps, but here is what I ran across:
Pulling the axles is easy with an SST type tool as shown in the repair manual - it is OTC tool # 6541 / 519375 - can be used with regular slide hammer.
https://www.clublexus.com/forums/per...ml#post8654177
HTH
Old 05-21-18 | 05:39 PM
  #114
MikeFig82's Avatar
MikeFig82
HTH
I was going to ask you about this when I saw your listing.
How's the top speed? Does it affect your MPH readings?
I'm planning to do this mod for my AWD this summer. Talking with Jeff he stated I shouldn't have problem dropping the 4.1 diff from a FRS/BRZ. Since my car is a 2010.
Old 05-26-18 | 01:34 PM
  #115
JETLEX's Avatar
JETLEX
Top Speed? Not sure, but then again I never got around to tracking the car.
Speedometer readings (MPH)? I never noticed a difference.
MPG? ~ 1mpg (or could have been me just having more fun)
Old 05-27-18 | 05:15 PM
  #116
Jeff Lange's Avatar
Jeff Lange
Keeping it Real
Doing this will not affect your speedometer readings.
Doing this in an AWD will have no effect on your gearing, as such it will have no effect on acceleration or top speed (beyond additional traction).
Jeff
Old 05-27-18 | 08:17 PM
  #117
MikeFig82's Avatar
MikeFig82
Jeff
Looking forward to getting this done.
Old 09-02-18 | 12:21 PM
  #118
NorthernIS's Avatar
NorthernIS
Do someone have access to the torque specs of the c-clamp and rack bolts?
Old 12-05-18 | 07:27 PM
  #119
NorthernIS's Avatar
NorthernIS
Default Done too!!!
Thanks to Jeff for all the info. I done it too. Love to learn stuff, so I taken the long way. Funny I found an almost new differential from a scrap yard, case was immaculate, and was supposed to be LSD. Turn out it wasn't so I continued my search and found a rusty one. Taken the LSD unit bought the Immaculate one and install the LSD into it. Case, rack and pinion have been saved, put new bearing in, check the backlash and the wear pattern. Finally put a powdercoat on the cover. Enjoy.
Old 12-06-18 | 08:56 AM
  #120
redspencer's Avatar
redspencer
OG Member
Beautiful work! It looks like it belongs as an OEM F-Sport accessory option!
