bulb assistance
bulb assistance
i had and inquiry about the types of bulbs that are underneath the side view mirror and the small bulbs that are inside the headlights in the high beam area but the small ones that turn on when you have the low beams on at night in the upper corners....... i was going to purchase led bulbs from superbrightleds.com
The light under your side view mirrors is called a puddle light. It should be replaced by a 194/168 base flank LED. Read this: https://www.clublexus.com/forums/is-...de-w-pics.html
The light in the corner of your high beam housing is called a parking light. It's also a 194/168 base but can be either flank or radially firing. Read this: https://www.clublexus.com/forums/is-...ive-guide.html
brociouz
03-31-18 04:35 PM
Lex Luga
02-17-11 05:08 PM
