V-LED LED DRL Kit no longer on site....alternative??
Looking for some guidance. I've had my 350 for a little over a week now and cant wait any longer to change out these ugly DRLs. I wanted to get the LED DRL kit from V-LED, but they pulled it off their website. I emailed them and Bill stated that they were revamping their DRL kits do to issues with certain vehicles.
He gave me a alternative stating the following are the items he thinks i may need:
Obvious, the bulbs
http://www.v-leds.com/part-id-s/9005...-h10-9145.html
DRL Module
http://www.v-leds.com/auxillary-back...ht-module.html
Resistor
http://www.v-leds.com/auxillary-back...-gs-is300.html
Seems like a huge pain in the ***. Has anyone done it this way?
Obvious, the bulbs
DRL Module
Resistor
You wouldn't need the resistors, just the bulbs and decoders.
Not sure why they'd redesign unless they're faulty or making them smaller. Right now none of the kits out there are easy to install (as in drilling/cutting moisture shields, opening housing).
That being said, if there's a problem with the kits, buying just the parts to complete the kit wouldn't fix the problem...
He will need all the above to really take advantage of the LED's brightness.
In the beginning, I only installed just the bulb and it flicker constantly and wasn't bright enough so I went ahead and install everything that came with it.
Wow, after installing the drl module and the resistor what a difference. Twice as bright.
your wrong.....he will need 1 of each and a pair of bulbs. I purchased the kit 4 months ago and it came with a pair of bulbs, 1 drl module and 1 resistor harness.
https://www.clublexus.com/forums/is-...-drl-help.html
thanks to whoever started this post, I was able to do it myself. Little over an hr for install. EASY DIY!
Obvious, the bulbs
DRL Module
Resistor
Obvious, the bulbs
DRL Module
Resistor
The latest generation V-LED LED DRL kit was 100% plug and play (no drilling), doesn't get much easier than that. Apparently they're being revised now though.
did you need a module of each bulb?
any problems with flickering or bulbs going out?
metaleckz
05-28-14 05:20 PM
brociouz
15
01-16-11 03:34 PM
