1000 mile service...should I go?
Mine is actually about 100 miles over 1K mark now. But I was curious what exactly is done in a "1000 miles service?" A quick search tells me that they can set the various features of the car to your personal liking (such as how long the headlamp stays on when after you turn off the engine on auto headlamp mode) but it's not like I was given a comprehensive list of things I can set from Lexus if such thing exist? What did they do when you brought your car in for it? It's free?
Went there last week, it is free, and I believe they just did an exterior/ under the hood inspection and adjust a few things to your personal preferences, and thats it. Took them about 45min.
https://www.clublexus.com/forums/2334636-post4.html
Other than getting LPS done, or pointing out any issues you found with the car as-delivered (my dead pedal was loose for example) there's no reason to go.
YES YES YES... You should change the Oil without question. Our motors have a tendency to build up shaved iron filiments. This is normal, but extremely excessive from break in on the first 1000 miles. The only way to remove them is to change your oil... SO YES YES YES TAKE IT IN... if they dont mention it... ASK THAT THEY CHANGE YOUR OIL!
It depends on how far you are from the dealership. Mine is close to an hour away so I skipped it. They will not change your oil at 1k (at least not for free, and not unless you ask them to). I had to push hard to get them to change my oil at 5k, as they were only going to do it at 10k (which is over a year for me). So I had them count my 5k as the "free" 10k and changed the oil then. I don't buy in to the "change it at 1k" stuff, but to each his/her own.
Im not selling anything....
If you ever have built a motor you will know that metal shavings are just a part of a machined motor... Simply look at some of the results from Blackstone Oil Analysis..... There is a whole thread dedicated to oil analysis of our cars used motor oil... ALL motors have metal shavings, however the LEXUS IS has more then average... If you look at any good machine shop they will tell you to run store brand oil (IE NAPA OIL) for the first 50-60 miles, then change it... you will clearly see the shavings at your first oil change.
The only problem I have so far is the slight paint bubbles in front of headlamps. Anyone mentioned it at 1K service? Seeing that Lexus still doesn't seem to have a clue as to how to fix the problem (though I think a simple design change will do the job), I'm afraid even if I replace them now it will eventually bubble again...that is, IF they agree to replace them. So maybe I should wait until the bubble gets worse and cross my finger that Lexus will eventually come up with new parts?
And in it you'll repeatedly see cars who went 5-10k miles on their original factory oil with no problems whatsoever and excellent UOA reports.
Your "built engine" example isn't very good though, because it's not like they're hand-porting the cylinder heads on the factory-assembled motors or something.
If you can cite any example, ever, of a 2IS owner having any problems whatsoever from waiting till at least 5k or more before doing their first oil change, I'd love to see it.
I suspect no such thing exists though.
I didn't notice mine until after my car hit 1000 miles so I brought it up at the complimentary 5k / 6 month service. The service representative said the other 2011 ISs on the dealership lot have it as well but he hasn't heard anything from Lexus. He says my headlights weren't warrantable unless the paint started chipping off. I called Lexus Customer Satisfaction regarding the headlight paint and they ended up agreeing with the dealership and did not mention any fix to the problem either. I was thinking the same thing though... even if they did replace them, unless they fixed "the problem" itself, it would probably just bubble up again.
