I wanna do my own oil change ...Best oil etc..
MAKE SURE TO USE TOYOTA BRAND FILTER
![](http://i1218.photobucket.com/albums/dd418/ramair11/Lex.jpg)
http://www.youtube.com/watch?v=URdoyzKGqFw
This was when I tried another one! DONT IT DOESNT FIT RIGHT...
![Woot](https://www.clublexus.com/forums/images/smilies/woot.gif)
Literally any synthetic made will be fine for 10k changes.
Folks have had good results from conventional oil and 10k intervals for that matter.
If you're gonna bother to run a synthetic I'd suggest running at least 15k (with a filter change halfway through). Even Mobil 1 should be fine for 15k... and a really good group IV synthetic like Amsoil will be fine to at least 20-25k (might want to change filter twice if running to 25k though).... if you only drive 15k in a year just use the Mobil 1... if you put on 20-25 might wanna go with the amsoil so you can keep it to 1 change a year.
These guys changing synthetic oil every 5k are literally pouring money down a drain.
NOTE: The above is for normal driving conditions- If you do severe duty driving (lots of short trips where the engine never gets to operating temp for any length of time, excessive idling, lots of driving in dirty/sandy/dusty places, etc) then you'll want to use the cheapest conventional you can find, and change it considerably more often.
As always UOA will be the best way to be sure of the ideal OCI interval for YOUR car and YOUR situation...but the above is a pretty decent guide.
Thanks for the info Kurtz!
I always use Mobil1 oil and OEM filter, I change every 5k miles but since I drive my car a lot(mostly highway) 5k miles lasts me 2.5months. I'm just wondering if it's really safe to change the oil more than 5k miles(we all know oil service lights up every 5k) especially like me that put a lot of miles. At the same time, I don't wanna have any problems later on as I'm planning on keeping my car til it stops running. TIA
Why would you want to "TRY" and stretch your oil out... The recommended interval is 5k... Pouring money down the drain... Hardley, This isnt our 1998 Dodge RAM from Kentucky. C'MON GUYS... WTF IS 30 bucks 2 times a year? You drive a Lexus, not a Toyota Corolla! Do the recommended maintanance schedule!
I understand most of the oil manufacturers are going to tell you to change it when the auto maker says to, for liability reasons and frequent changes = money in their pocket.
Is there a place I can do some good reading on this that is not a retailer, or "experts" on a forum? (No offense to those that have done some true research)
Why would you spend 2-4 times more on oil changes for no benefit?
because that's what you are recommending people do.
My last two cars were a 500+ hp vehicle, where I change the oil 1/yr, and never had a problem (Amsoil, good to 25k miles per change)... and a wagon with just under 200,000 miles when I got rid of it, also 1/yr changes.
The 2IS has a vastly more modern engine than either that is much easier on oil...so why in the world would I waste money changing it more often?
You are pouring money down the drain. You're changing your oil far too often for no benefit whatsoever.
Again, show me any IS, ever that had a failure related to long oil changes.
You can't.
For that matter, Amsoil will pay to replace your engine if it ever fails running an OCI with their product.
Know how often they've had to pay that out in 30+ years in business?
Never.
because frequent oil changes are for suckers.
the only people who benefit from em are the people selling you the oil. Your car sure doesn't.
Oh... and the factory interval with synthetic is 10,000 miles, not 5k.
Check the manual on a 2011 sometime (which comes with syn from the factory).
So even the folks who built the car say you're wrong.
I'm not saying fresh oil is a bad thing. I'm just trying to sift through the hearsay and scientific studies.
Do you have any proof that it's better for the motor, or that synthetic breaks down after 5K miles? Some kind of normal distribution curve of oil life? Why do some BMW/VW motors have such a high OCI?
The only way to really know is to get your oil analyzed by a lab like Blackstone.
I go with synthetic and do around 8K miles or one year changes.
