Bounced off from rev limiter...
I only use the paddles to downshift when coming down a hill etc. At the bottom, when I then step on the accelerator I simultaneously hold the "+" paddle for a few secs & that automatically removes the gear limiter ( ie puts that setting back to 6th). So you don't have to click the "+" multiple times, just hold it to accomplish the same thing.
If you're not sure where the yellow dipstick is in a virtually black engine bay, then maybe the paddles should be something you learn later
Based on insideline's description, it actually appears as though the system in the 2013 GS is different from that in the current generation IS (our cars certainly don't "rev match" in maximum gear limiter mode) but is not the same system implemented in the ISF -
My only real dynamic gripe about the 2013 Lexus GS 350 is with its transmission. Although it matches revs very well when you manually ask for a downshift, it only matches revs if the shifter is over in the M position. Otherwise the paddle shifters are still active but the rev-matching is not.
The transmission also insists on upshifting at redline, even when the M position is selected. In other words, Lexus never lets you touch the V6's rev limiter. This is a problem in the mountains. More than once it upshifted to 3rd gear a split-second before I jumped on the brakes and entered a corner. Not good.
Even if it is a true gear selecting system, the fact that the car automatically up shifts at redline is still disappointing.
Sorry to burst your bubble but you're using the paddles in entirely the wrong way. They aren't shifters at all.
The IS350, for all intents and purposes, is a fully automatic transmission car.
The only time the paddles (which are maximum gear limiters - not gear selectors) are potentially useful is for roll racing. If you want to race from a 40 MPH roll, you want to slow to 40 MPH, set your car to S2, accelerate when the race starts, and then immediately (while you have the accelerator down) press the + paddle 4 times in succession as quickly as possible or shift the lever from "S" mode to "D" mode. Either method works.
It doesn't matter when you press the "+" paddle while going WOT. You can never be too early, but you can be too late. Therefore, it makes no sense to wait. The only reason people wait to press the "+" paddle while going WOT is that it gives them the illusion that they have some control over shifting, when in reality they have no control at all. The automatic transmission decides when the car shifts taking into account maximum gear limiting constraints you may place on the transmission via S mode.
The ISF, however, does have a true paddle shifting system in sport "M" mode.
It also has the same, useless "maximum gear limiter" S mode system that the IS350 has, but nobody on the ISF forum uses it.
As far as I recall, the new 2013 4th generation GS has implemented the true paddle shifting system that is present in the current ISF, so that may bode well for the 3rd generation IS.
