Where is the oil change light?
Hi everyone,
New guy here, great forum with lots of good info. I just acquired my 07 IS 250 with 50K miles two days ago. I checked the oil and it still looks good but I called the original dealer (JM Lexus in Fl) to see when my car was last serviced, the oil change was July 2010 at 42K. I just read that there is an oil light on the display when you need to change the oil. If I don't see it in my car should I still go ahead and change the oil?
Thanks,
Thanks,
Super Moderator
The center display above the speedo (that shows temperature, mileage, range, gear, etc.) will say "Oil maintenance required" and illuminate the big orange caution exclamation point every 5,000 miles. It's not like a BMW where the oil change indicator calculates oil life based on driving habits, the one on the Lexus just counts the miles. It's easily reset at any time using the instructions in the owners manual or our FAQ posted at the top of the forum.
Since it's possible your car has conventional oil with 8,000 miles on it, and because I'm a big fan of synthetic oil, I'd probably change it if it were my car.
What filters are you guys using?? ive ALWAYS used mobil 1 or K&N oil filters but the 2IS has a POS cartradge and they dont make them and the only ones ive found are fram (junk) oem (pita to get) and purolator (meh better than fram.. barely)
