Help... Car keeps overheating!!!!!!
Old 09-07-11 | 05:57 PM
RobzKar's Avatar
RobzKar
Default Help... Car keeps overheating!!!!!!
Ok so I've been having this problem for awhile now. When I'm just parked with the AC on it starts to overheat. The temp outside is hot but not scolding hot. So I'm wondering if it's the thermometer, but if it were then wouldn't it get hot even when driving? Can anyone give me some advice on what to check or do. Thanks.
Old 09-07-11 | 06:04 PM
Bichon's Avatar
Bichon
Super Moderator
First thing I would check are the fans that blow air over the radiator and condensing coils to insure that they are running. When the car is in motion, air naturally flows through the radiator grill and over these, but there is nothing but those fans to provide airflow when you are stopped.
Old 09-07-11 | 06:54 PM
RobzKar's Avatar
RobzKar
The fans work. I checked. Whats the condensing coils?
Old 09-07-11 | 07:00 PM
accelerate's Avatar
accelerate
Yes your fans are working, but that doesn't mean they are working correctly. Sometimes when three go bad there just not spinning fast enough. Thus not blowing enough air threw the radiator. Thie will cause you to over heat.
Old 09-07-11 | 07:48 PM
RobzKar's Avatar
RobzKar
Let me ask you guys, should I change the thermostat and go with aftermarket fans? Any other suggestions would be appreciated. Thanks again.
Old 09-07-11 | 08:00 PM
VIS250P's Avatar
VIS250P
Go check the water pump.. See if there dry pink liquid all over the front motor
Old 09-07-11 | 08:15 PM
RobzKar's Avatar
RobzKar
If there is then does that mean the water pump is messed up cause I've seen that already... My GF was in the car waiting for me one day and the car started to overheat so she just turned the car off, all kinds of pink liquid looked like it overflowed through the reservoir and so I replaced with antifreeze. Ever since then it over heats when parked, not all the time just some times.
Old 09-07-11 | 08:57 PM
ljdsong's Avatar
ljdsong
If there is overflow, it doesnt mean your waterpump is broken. If your fan is all working thats fine, maybe you have to change your thermostat, but not the ffail one that constantly open, get the stock thermostat. You will have a problem if you get that fail one especially during the winter time.
Old 09-07-11 | 09:00 PM
kamileon88's Avatar
kamileon88
water pump water pump and water pump. never seen a thermostate fail.
Old 09-07-11 | 09:31 PM
calvin2376's Avatar
calvin2376
I have, on my E55, and I just read a recent thread about a CL member whose 2IS thermostat failed.
Old 09-07-11 | 09:47 PM
ISBU's Avatar
ISBU
Check the temperature of upper and lower radiator hose. If one is really hot and the other is warm the water is not circulating. The water pump is broken or the thermostat stuck close. Also, pressure test your radiator cap. Compare the fan speed with other IS to see if there's a difference.
Old 09-07-11 | 09:57 PM
RobzKar's Avatar
RobzKar
Thanks guys for all the input. Iv decided to go ahead and order a water pump and thermostat due to the year of my car. I feel that it's probably time to replace it.
Old 09-07-11 | 10:22 PM
Sffd103's Avatar
Sffd103
Fire Slayer
How many miles do you have on it by the way?
Old 09-07-11 | 10:23 PM
Rikg35's Avatar
Rikg35
Change the thermostat, check hoses, fans, also the water pump. This sucks cause its hard to find.. worst case itsthe heads. this happened to my civic and I changed everything. Possible finnally it ended up being the heads.. good luck.
Old 09-07-11 | 10:49 PM
RobzKar's Avatar
RobzKar
Thanks guys. It's got close to 140K but still runs like a beast.
