DRL/HID problems
DRL/HID problems
Got the Xenon White 9005 HB3 LED Daytime Running Light Bulbs + DRL Decoder Kit from iJMDtoy.com. Installed them w/out the decoded because I didnt want to do the drilling of the dust cap. They flicker a little but still run (talked to iJMDtoy and they said its fine), after about 3 weeks I noticed that my right HID is turning off after a couple minutes of running. If I switch the light off/on it comes back. Anyone else having this problem? Or feedback?
Thanks in advance
Thanks in advance
after properly connecting the DLR, you HID ran right? I was a little concerned that it might be an electrical issue since I didnt touch any HID parts/bulbs when installing the DLR's 9005
Thanks in advance
Thanks in advance
Could be a ballast too. Put the halogens back in and see if the HID still goes out as well.
Believe they are still in R&D testing. Jason @iJDMTOY said they are not publicly available yet.
Thanks for the info, I swaped the bulbs and found it that I need some new bulbs
hello i actually just bought the same kit from ijdmtoy and i installed them with the decoder. they did not even turn on and then, when i switch them back to the stock dtr/hb 9005 bulb they completely dont work at all. any ideas? i dont know what to do. thanks..
I also tried that with the kit installed. turning on the engine. they completely did not work so i switch back to stock. and even now the stock dont work and when i use my highbeam now it seems like its my headlights slightly aiming higher. (i hope that makes sense) No light at all to my dtr/hb. Can I reset it or something?
Sounds like you had the connectors backwards or not pushed in far enough.
The directions said to absolutely make sure you plug in the right +/- sides of the connectors. I don't know if the iJDM's have a safeguard against reverse polarity.
sorry for late reply i guess during install my fuse blew. I replaced it and it works fine. very dim though. now it trying to figure out how to put the dust covers back on. thanks for the help people
